Question about Schlage Locks & Locksmithing
How do I down load Schlage Sense app - Schlage Locks & Locksmithing
Posted by Frank Somma on
Keyless schlage lock opens when schlage button is pushed
  1. Remove the two screws on the back plate.
  2. Disconnect the battery
  3. Remove the two screws on the inside of the lock so that you can remove the entire lock.
  4. Once you have removed the lock from the door take the backplate in hand
  5. Right above the orange plastic piece there is a small black egg shaped cam.
  6. Turn the black egg shaped cam to the side and then turn it back down so that the arrow is pointing down.
  7. If you do this right the deadbolt will stay in the unlocked position. The deadbolt will not retract when you turn the cam because it should be completely disconnected
  8. Once you do this correctly you will reinstall the lock in the unlocked position.
This also will fix the light not coming on when you press the Schlage button.
Dec 15, 2017 | Schlage Locks & Locksmithing
Schlage keyless door lock wont lock
Can you provide more details? I've had similar problems with Schlage Sense and August Smart Lock. So I might be able to help you.
The first thing we should try is reseting the lock and try setting it up as brand new one.
Mar 21, 2013 | Schlage FE595-CAM-ACC FE595-CAM-716-ACC...
Shlage keypad dead bolt unlocks when you press the
Does my Schlage BE365-CAM BE365CAM505 have a feature that allows it to automatically lock the deadbolt without having to enter code and turn the dial?
Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the dial. When disabled, you have to enter the user code, then turn the dial.
To enable/disable this feature, enter your Programming Code--press the Schlage button--Press 7.
Each time you do this, you toggle between enabled and disabled.
Videos for installing and programming can be found on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Scroll down and find them under the heading Electronic Security--Keypad deadbolt 365
Aug 31, 2012 | Schlage Camelot Deadbolt Keypad, Satin...
Htc sensation stuck safe mode
This happened to me on HTC Sensation. I was able to get into my apps after a few attempts to reboot seems when volume is all the way down during a reboot it initiates the safe mode. this can happen, im told for many, reasons. Even if your volume controls are working fine.dust etc. although I followed the directions listed above I cleared the htc sense cache then re*stareted and all loaded just fine. I just had too do a little rearanging to my apps on home page . so I am pleased I saved a service call
Mar 27, 2012 | HTC Cell Phones
I need to set/change the code on my Schlage lock but the sticker is completely unreadable.
I do not believe you will be able to reprogram the lock without the programming code, usually found on the sticker (unreadable, in your case).
Therefore, I urge you to call Schlage directly-they may be able to help you. here is the contact information:
United States Customer Support
Warranty & Technical Information: 1.888.805.9837
You are right about the support link going 404-It used to work. Get there by going to:Schlage.com
and clicking on "For your home"
Mouse over the "Service & Support" link, then go down & left click on "Instruction & Manuals". There ya go!
Feb 14, 2012 | Schlage FE595VCAM716ACC Camelot Keypad...
Schlage model number BE365 serial number 1-01186093 owners manual
Here is the link to the on-line manual. It may take a few seconds to load:
http://consumer.schlage.com/Project%20Documents/P515-858.pdf
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Jan 28, 2012 | Schlage Locks & Locksmithing
Schlage camelot key pad does not engage exterior locking knob when you press the schlage button. I have tried three different locks.
Here is a link to the installation instructions:
It sounds like you may have the Turn Lock Feature disabled. View and scroll down in the instruction sheet to the Troubleshooting portion, where it says " Pressing (the) Schlage (button) does not rotate deadbolt" The solution is to push the PC button, then the Schlage button, then 7 to enable the turn lock feature.
Here is the contact info you need for customer service:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
May 02, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
Schlage Cobra lock. The lock will not lock
Please re-post your question with more specific information about the problem.
Olathe, KS 66061
Schlage FAQ: http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx
http://consumer.schlage.com/Service-Support/Pages/FAQ.aspx
Instructions & Manuals: http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Mar 18, 2011 | Schlage COBRA by Keyless Lock
My keyless unit lock from the inside but when I push the outside schlage button to turn the bolt from the outside it just spins - what now?
On this web page you will find installation/troubleshooting information and videos for the BE365, if you scroll down to the Electronic Security section.
If you are unable to find your own solution, please contact their Customer Support. here's the link:
Feb 13, 2011 | Schlage Lock BE365VCAM716 Electronic...
I press the schlage button i can unlock the door by turning the button
Complete installation & programming instructions can be found here:
Notice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
Scroll down and find them under the heading Electronic Security... 365
Good luck--and please provide feedback if this helps!
Nov 06, 2010 | Schlage BE365-CAM BE365CAM619 Satin...
Locks & Locksmithing Logo
245 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Mike
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
