Question about Panasonic Video Cameras
SOURCE: Need Panasonic SDR-H40 software download
You can connect to any computer with a USB port. It appears as a hard drive after you tell the camera to connect (in the menu). Then just copy the .mod files to a spot on yor computer; there will be one for each movie clip.
Your next chore is changing them into MPEG files at the correct aspect ratio. If you shot in 16:9 they will be squished together unless you use the SDCopy freeware utility to set the widescreen flag. It also renames and downloads files for you, and it's small. There's a link from this tutorial page, which also explains a lot about aspect ratios and such:
http://www.elurauser.com/articles/JVC_Everio_mod_files.jsp
Posted on Feb 08, 2009
SOURCE: panasonic sdr-h80 will not download videos to pc.
u can download here put your download driver query here and download driver free for refine your search use drop down section
Posted on Oct 24, 2009
SOURCE: Panasonic SDR-H80, Need service pack for video cam
I hope you have WIN XP on your computer. Windows XP has 3 versions of service pack (SP) available. SP1, SP2 and SP3. For more information on obtaining SP, please refer:
http://support.microsoft.com/kb/322389
Following is the direct link for downloading SP3
http://www.microsoft.com/downloads/details.aspx?FamilyId=68C48DAD-BC34-40BE-8D85-6BB4F56F5110&displaylang=en
NB: SP is a huge file and will take long time depending on the speed of your internet connection. SP2 download would fail in 'dial up' internet connection. Also installation of SP will take a long time, depending on the configuration and the performance of your system
Posted on Dec 16, 2009
SOURCE: software incompatible window 7
Step by step instructions for Windows 7 32-bit follow:
Insert the Panasonic CDROM.
Don't use autorun - Cancel autorun popup.
Right click on CDROM drive in "My Computer" and select 'Open'.
Right click on Setup application & choose 'Troubleshoot Compatibility'.
Select 'Troubleshoot program'.
Select "The program worked in earlier versions of Windows but won't install or run now' & click
the "Next" button.
Select 'Windows Vista (Service Pack 2)' & click the "Next" button.
Click on "Start the program..." button.
Proceed with program installation.
When installation finished cancel out of the 'Program Compatibility' window.
If you have Windows 7 64-bit the instructions are:
Insert the program CDROM.
the "Next" button.
Installation will start.
VideoCam Suite will probably be flashing on the taskbar so select it.
The window will show: 'This application does not support this 64-bit operating system. Are you
sure you want to install?'
!!! Click the "Yes" button !!!
Posted on Jan 03, 2010
SOURCE: dvd software wont download for my sdr-h80 in
Dear i hope this answer will right for the solve your problem.
And for solution of your problem.
i have send this link for your problem.
This software is for Windows 2000/XP/Vista only! You can download Windows 9x version from here.
Posted on Feb 14, 2010
Nov 26, 2016 | Panasonic SDR-H80 Hard Drive Camcorder
Jul 14, 2011 | Panasonic SDR-H80 Hard Drive Camcorder
Apr 30, 2011 | Panasonic SDR-H80 Hard Drive Camcorder
Dec 20, 2010 | Panasonic SDR-H80 Hard Drive Camcorder
Nov 19, 2010 | Panasonic SDR-H40 HDD Camcorder
Aug 19, 2010 | Panasonic SDR-H40 HDD Camcorder
Feb 14, 2010 | Panasonic SDR-H80 Hard Drive Camcorder
Dec 06, 2009 | Panasonic SDR-H80 Hard Drive Camcorder
Jul 01, 2009 | Panasonic Electronic Whiteboard Mobile...
232 people viewed this question
