Question about Blaupunkt Televison & Video
My blaupunkt tv I tried to turn it on with remote but would not turn on I kept trying and the colour changed to blue but now it is just flashing red and blue continuously can't do anything with it
Posted by Christine richards on
Tom Chichester
    Top Expert:
  • Blaupunkt Master
  • 55,379 Answers
Could be an open internal fuse or power supply failure
Posted on Apr 11, 2018
5 Related Answers
Anonymous
SOURCE: TV just flashes different colors
You have entered a diagnostic colour test. With the TV powered on, hold the 'Menu' & 'Enter' together, then press the power button. Problem resolved
Posted on Sep 03, 2006
Jaime Hernandez
  • 2337 Answers
SOURCE: Toshiba TV, no power, red light flashing
Unplug the TV for 2 minutes and plug it back on.
It should work.
Posted on Feb 09, 2008
Anonymous
  • 271 Answers
SOURCE: viewsonic n2750w 27" turn on the tv it gets 4 different colors
if you have a reset button (might be hidden)...hit dat
Posted on Dec 17, 2008
alpug
Danilo Baraquiel
  • 1961 Answers
SOURCE: TV doesn't turn on - red lindicator light is just flashing
check and replace your horizontal output transistor as well as the regulator..
Posted on May 17, 2010
paul4265
Paul Pope
  • 592 Answers
SOURCE: TV will not turn on. Red flashing light, nothing
Hi.
This sounds like you are experiencing the same thing as thousands of other tv owners right now.
Your tv is suffering from " capacitor flu".
The capacitors that control voltage regulation, convergence, or the ones on the main board have failed.
This is not due to anything that you have done, it is because about 15 years ago, some companies chose to put profit ahead of quality.
There were about 20 electronic component manufacturers in the mid-1990's that mass manufactured capacitors, and they were done so with the wrong formula for capacitance gel. They used a formula which was later determined to be harmful to the capacitors, but instead of pulling those off of the market, they ignored the massive failures and left then out there on the market anyways.
All together, the companies made a combined 50,000,000 capacitors that were junk, and instead of lasting the 25-30 year design like they were supposed to, some of them are only lasting a few months to a few years, at best.
Now, that isn't to say that this means that your tv should be tossed in the trash, but if you take it to get it repaired at places like BestBuy, Fry's, or Staple's...you will want to get an estimate of repair costs before actually having it done.
The reason for this is because to get the proper capacitors put in your tv is a time consuming, and expensive repair.
You may find that the cost of repair is more expensive than the cost of replacing the tv, or you may find that it reasonably priced to get the repair.
That is why I recommend getting an estimate first.
This way, you will know ahead of time which way is the most economically feasible venture for you.
I hope this helps you understand what is going on with your tv, and that it gives you some insight as to how to remedy the situation.
Good luck to you, and have a good day.
Posted on May 31, 2011
My flat screen Sylvania TV is flashing different colors what's wrong
Better late than never. The problem is that your TV is in the service mode. There are many ways this can happen. But, lets just get down to fixin this! With the original remote and the TV on. If the TV will not shut off, do this. Press the left cursor button on the remote, followed with pressing the right cursor. Power off the TV with remote, or press off button on TV.
Secondly, your TV will power on and off. But you have flashing colors. Do this. With the original remote and TV on. Press the up cursor button, on the remote, followed with pressing the down cursor. Power off TV with remote, or press off power of TV. Thanks for asking me, Matt of Martins TV Repair.
Jan 20, 2016 | Sylvania Televison & Video
4 digit TV code to set up to BT youview
You might need to reset the remote control if the codes don't work.
If you've got the BT YouView remote that came with the box (with the 'BT Vision' button on it), hold down the two buttons either side of '0', whilst also holding down the power button for around 5 seconds. The blue light on the remote should flash three times to confirm it's successfully reset.
If you've got the retail YouView remote (with the 'TV' and 'PVR' buttons on it), press and hold the 'TV' button and the red coloured button at the same time for 5 seconds. The 'TV' and 'PVR' buttons should flash red 3 times to confirm.
Try your codes again after. I believe 4483 is the code in the setup guide.
May 28, 2015 | Televison & Video
Remote control code required for virgin TiVo & 50 inch blaupunkt TV combo
I have just managed to do this. I cannot tell you the code as I had to do it manually, but this is how I did it.
point the remote away from the TiVo and hold down the clear button and the to button until the free light flashed twice.
type in the code 0999 and the light will flash again. Then point the remote at the to and press and hold the channel up button. You will now scroll throw all the codes.
it will take about a minute but eventually the to will go off. When this happens release the channel up button and hold down the green on button to try turn the tv on with the TiVo remote.
if it comes on press ok and this will store the code. If it doesn't come on, use the blaupunkt to remote to turn the tv back on and then keep holding down the channel up button to scroll through more codes. When the to goes off again release the channel up button and try turn it on with the TiVo remote. If it works this time store the code by pressing ok
for me it took two attempts to turn the to on but eventually it worked on the second code
Nov 29, 2014 | Blaupunkt Car Audio & Video
Will not store settings unless kept in standby. Contrast/Brightness/Colour/Volume
1. The on/off switch is not easily accessible because the remote control is used to turn the TV on and off.
2. If the remote is used, the TV is always in standby mode
3. When the power is turned off and then back on those settings go back to their preset values or the last preset settings.
4, You should be able to enter the preset settings with the original remote control,
Sep 17, 2017 | Watches
Flashing 3 colors red, green and blue to turn it off I had to unplug it. Trying to switching from TV to DVD. This have happened before. I don't have a remote but the service man reset it some how
Download the user manual to your TV. It will have all details about how to reset it to factory default. A factory default set should be done now. To download its user manual, click here.
Jun 21, 2012 | Sylvania LD320SSX LCD TV
The people are blue and we have no option for changing the colour
the component video cables are switched around. there are 3 colors for video - green, blue and red
two for sound - white and red
make sure you didn't swap the red cables, or swap the blue and red, this is most likely the cause of your issue, check on both the sat box and on the tv
let me know if you require further assistance
Jul 11, 2010 | LG 42LC2D 42 in. LCD HDTV
Blocks of Colour displaying
 This tv has severe problems in the image processor - you bought a dud. Try getting your money back.
Jun 26, 2010 | Samsung Televison & Video
My ViewSonic TV suddenly stopped working. The
hi do you mean the colour flashing on the screen, if so it's gone in to screen burn mode try press menu on the remote, retune the tv, if this don't work get back to me with model number of the tv help you a bit more thanks
shaun
Jun 12, 2017 | Televison & Video
Bush RFT TV
The picture tube of the tv has 3 color in CRT Red, Green, Blue. The red cathodeof tv set has no function, its either the resistor become higt resistance, that why u need a repairman to replace it.
Apr 10, 2008 | Televison & Video
Televison & Video Logo
2,870 people viewed this question
Top Blaupunkt Televison & Video Experts
Marvin
Marvin
Vernon Taylor
Andrew Taylor
Andrew Taylor
Are you a Blaupunkt Televison and Video Expert? Answer questions, earn points and help others
