Question about Electrical Supplies
Starter solenoid troubleshooting for primepact 50 model 02010-2 Rv genrac generator
Posted by Ralph Pizzacalla on
1 Related Answer
Anonymous
  • 142 Answers
SOURCE: My Generac Primepact 50 RV generator has no AC output.
Check the exciting field wires and fuses.
Posted on Jun 04, 2010
Where are the exciting field wire fuses located
Try putting 12 volts DC across the commutator coils at the brushes, sometimes the generator looses it's magnetic field and this could possibly restore it but make sure it is a low current not a car storage battery.
Good luck,
Marty
Jul 16, 2014 | Generac 5 kW, 60Hz Model PrimePact 50G RV...
My generac rv generator runs bu no voltage output.
Try putting 12 volts across the commutator at the brushes. Ust a low current battery nor a car storage battery.
Good luck,
Marty
Jul 16, 2014 | Generac 5754 4.8 kW 120/240 Volt PrimePact...
I have a Guardian RV 3600 watt generator than wont run more than a few seconds. I have to hold my hand over the breather to get it to fire then as soon as it revs up it shuts off.
carburetor restricted due to long time storage drop carb fuel bowl unscrew the jet and pull down the fuel tube clean them and your generator should run much much better
Aug 16, 2013 | Guardian Rv Generator 4800 Watt, Gasoline,...
Where is the starter on a primepact 50g
follow red thick wire on right side of the solenoid the starter is on right side rear hidden by the air box that surrounds the gen.
Aug 01, 2012 | Guardian Rv Generator 4800 Watt, Gasoline,...
My generac 40g rv generator will start fine but no power. I noticed that when it starts the microwave will power up for just a second. I can turn the generator off and on a couple of times and then it will...
It may be demagnetised. If you turn off the generator before unplugging the load this may happened. Try to put a strong magnet (like those from loudspeakers) in contact with the body of alternator. I do this in the past and it work.If you do not know how to do this ask an electrician, he can help you .
Sep 30, 2010 | Guardian Rv Generator 4800 Watt, Gasoline,...
Guardian rv generator
Your control board is faulty. Try to power up the ingnition coil as well as your fuel pump. If this does not get the engine running then you have major engine problems.
May 18, 2009 | Guardian Rv Generator 4800 Watt, Gasoline,...
I have a 7500 watt guardian rv generator and it is difficult to start if not used on very regular basis. It cranks but will not fire. If I go out and manually fool with the choke it starts. Obviously it is...
Before starting the genset remove the air filter and check the throttle plate on the carberator, it should be closed. If it is opened, then you choke coil is worn out and needs to be replaced.
Apr 19, 2009 | Guardian Rv Generator 4800 Watt, Gasoline,...
Have a 16k propane guardian generator have to manually start and
Is this an RV generator?
If you have to really choke an LP engine but it runs more or less normally once started you need to troubleshoot the demand regulator and the fuel supply lines (look for air leaks). I'd also check the fuel inlet pressure before the demand regulator.
Rate me,
Carl
Nov 19, 2008 | Guardian Rv Generator 4800 Watt, Gasoline,...
Electrical Supplies Logo
73 people viewed this question
Top Electrical Supplies Experts
john h
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
