Question about Intel Computers & Internet
How to connect hard disk model J880 to intel core duo?
Posted by amirkhan on
5 Related Answers
Anonymous
SOURCE: IBM ThinkPad T41, Upgrade my Intel Centrino Processor
make sure that the socket supports your new max Intel.
Posted on Feb 05, 2009
Anonymous
SOURCE: Mac Intel OX 10.5.5 drivers not loading and working
I had this same problem with my MacBook Pro Intel notebook running the latest Mac OS. I went to the OKI web site ( http://my.okidata.com/pp-C5200n.nsf/openingdrivermenu?OpenFrameSet ) and downloaded the OKI C5000 GDI Intel driver. I followed the install instructions to load the driver. Next, I went to system preferences and selected printers. Then I selected the + button under printers. My current printers showed up on the list. I then selected "More Printers" and the other drivers loaded on my Mac were listed. One option was OKI USB. I selected this option THEN I plugged my USB cable from the OKI into my Notebook. The computer recognized the printer. I hit Save and I proceeded to print my first document. FYI: I spent several hours trying to get this thing to work yesterday with the USB cable already plugged in. I don't know why it would not work. This worked for me. Good luck.
Posted on Jun 05, 2009
XOUSS
Daily Mehdi
  • 48 Answers
SOURCE: difference betweeen intel celeron,core duo, mxx
Hello , Intel processors come in all shapes and sizes so I'll try to be brief by discussing only the ones that are current on the market. The market for intel processors are currently divided into 2 sides. One side if for single core processors while the other is for multi-cores. Single cores: Pentium 4, Pentium M, Celeron, Core Solo (Not very common) These cpus are single cores meaning that they only have one processor. They are relatively cheap compared to multicores. The difference between these are clock values, hyper threading, 64 bit support, and FSB. Pentium 4 and Celerons are cores found in desktops while the M is found in laptops. Single cores generally have low FSB but high clock speeds. Think of it as having a lot of water pressure but only a straw to dispense it. That's how fsb and clock values work. So single cores should provide you with a lot of raq power but they're not good at multi-tasking or jobs that requires it divide it's attention. Games like Crysis will be better with multi-cores because the pc has to generate so many different things at once while focusing on countless calculations and processes. the hyperthreading support does help the single core pentium 4s with multi-tasking but it's not as much as multicores. So if you're just looking for something with a lot of raw power. These are for you. Multi-Core Core Duo, Core 2 Duo, Core 2 Quad These are multi-core processors developed by intel. They are used in both laptops and desktops except for the quad. It's used in desktops only. The first 2 processors are dual cores while the last is quad cored. These processors have a high FSB rating and generally lower clock speed. So you have to be careful when looking at these. The high fsb means that the system does really really well with dividing and transferring it's processing power, but if you get a low clock speed then there's not enough power to begin with for the assignment. Example you may have a large hose but if you have low water pressure.. it's useless. That's why multi-cores are great for the modern pc user who multitasks way too much but if it's under 2.0ghz in clock speed. You should be worried about not having enough raw power to get you through intensive work. Multicores generally cost a lot more than single cores since they're relatively new technology. Btw the Core 2 Duo is faster than the Core Duo by about 7%. Meanwhile the quadcore is the ultimate in processor goodness but costs $400+. I hope these facts helped.
Posted on Jun 12, 2009
Anonymous
  • 28 Answers
SOURCE: f672cr(m1610)and intel core duo?
The Acer M1610 was available with the following processors: Intel Core 2 Duo, Intel Pentium Dual-Core, Intel Pentium D/4, Intel Celeron D/4 2.0GHz.
Based on this information, It is likely that you can support a Core Duo or a Core 2 Duo, however may be limited to the 2.0GHz models due to clock and multiplier limitations on the BIOS. This may be different if there is BIOS upgrades to support faster processors.
Your best option of the above listed processors will be the Core 2 Duo, however their system specifications report that only the Core 2 with 800MHz or less Front Side Bus are supported.
Also note that the Celeron 430 is a 64bit processor, so it is not likely to work on this system either.
Posted on Sep 06, 2009
Testimonial: "my current processor is intel pentium dual core.i'll get a core 2 duo with 800mhz or less.thanks"
Chito
  • 95 Answers
SOURCE: dell xps m1530 with intel core duo keeps freezing
To further investigate the issue you may do the following.
1.go to control panel --> administrative tools then select event viewer. check on system logs. you might be able to find a clue on why the notebook keeps on freezing after 15 to 20 minutes.
2.please check your virus definitions if its fully updated. If not please update it then do a full scan afterwards.
3. do a windows update on your system if it's not fully updated yet.
4. You may also check or try to remember what has been installed lately. It might be that the application installed have caused vista to freeze.
Or you may also check this link for another user who has the same issue.
hope this helps . . .
Posted on Apr 05, 2010
My Mac takes a long time betwen orders
no idea what that is, but slow mac are normaly the permissions need repairing and or the hard disk is failing, go to the disk utility in the utlilty's folder and check and repair the permissions, then maybe check the hard disk for errors, you will know if the hard disk has a problem as it will have red wrighting.
Mar 14, 2013 | Apple MacBook Pro Laptop Computer with...
How much gb hard disk support to Intel motherboard dg 41 WV
Intel G41 compatible with core 2 duo can support any Size of SATA Hard disk drive (Storage Device).
vote me if found helpful.
Aug 06, 2011 | Intel DG41RQ Motherboard & Core 2 Duo...
What is max.hard disc size supported by intel DG41RQ mother board(can it support 1 TB+80GB)?-help me please sir..................
Any motherboard that is modern-enough to support "dual-core" processors can support *ANY* size of SATA disk-drive that you can afford to purchase.
Jun 21, 2011 | Intel DG41RQ Motherboard & Core 2 Duo...
My motherboard model is D101GGC Is this support CORE 2 DUO E4600 processor
This motherboard model will not support Core 2 Duo E4600.
It will support only.
1.Intel Pentium D Processor.
2.Intel Pentium 4 Processor.
3.Intel Celeron D Processor.
Thanks for using FixYa.
Jun 03, 2011 | Intel D101GGC Motherboard
Can the Dell Latitude D610 run any of the following games: Age of Conan Star Trek Online Champions Online Aion
Check your system if it meets the following requirements
Age of Conan
Required
OS: Windows Vista/XP
Processor: 3GHz Pentium IV
RAM: 1GB RAM
Video Card: Shader Model 2.0 and 128MB RAM: NVIDIA GeForce 5800 or ATI 9800
Recommended
Processor: Intel Core 2 Duo 2.4 GHz (E6600) or better
Video Card: NVIDIA GeForce 7950GX2 or better
RAM: 2GB or more
Enhanced for: DirectX 10, 64-bit processors, multi-core
Supports Parental Controls on Windows Vista
Start Trek
System Requirements
  • OS: Windows XP SP2 / Windows Vista / Windows 7 (32 or 64-bit)
  • CPU: Intel Core 2 Duo 1.8 Ghz or AMD Athlon X2 3800+
  • Memory: 1GB RAM
  • Video: NVIDIA GeForce 7950 / ATI Radeon X1800 / Intel HD Graphics
  • Sound: DirectX 9.0c Compatible Soundcard
  • DirectX: Version 9.0c or Higher
  • HDD: 8GB Free Disk Space
  • Network: Internet Broadband Connection Required
  • Disc: 6X DVD-ROM
Recommended System Configuration
  • CPU: Intel E8400 Core 2 Duo or AMD Athlon X2 5600+
  • Memory: 2GB RAM+
  • Video: NVIDIA GeForce 8800 / ATI Radeon HD 3850+
  • Disc: 6X DVD-ROM
To check your system hardware> click on start>all programs>accessories>system tools> system information.
Thanks for using Fixya
proton
Mar 27, 2010 | Dell Latitude D610 Notebook
It doesnt detect my harddrive and it causes windows to crash...how do i fix it?
If the BIOS cannot detect the hard disk then probably the hard disk is faulty.
To check if the hard disk is faulty, remove the hard disk and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot detect the hard drive or open the folders and files, then the hard disk is faulty.
To get your computer operating again, replace the hard drive with a new one and install Windows on the new hard drive plus the computer's device drivers and your programs.
Mar 15, 2010 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Best gaming desktop configuration for 700$
dell has a good deal on a studio desktop pc Core 2 duo quad core but even without the monitor its 550, then you have to add a good video card, integrated cards are garbage and so is intel, so the good ones are anout $100-300 intel and amd
to keep cost down you could also go with a core 2 duo (dual core) but stay away from celerons they **** for gaming
check staples/office max/best buy/circuit city or dell dot com for good deals
some dell studio's are slim desktops and unless you get a video card from dell they can be hard to find(near impossible)
Jan 05, 2009 | Intel Computers & Internet
Cant install ubuntu 7.04 on Excelstor J880 SATA Drive
From what I know, both your motherboard and your hard drive work with Ubuntu. I would try the newest release, 8.04 (Hardy Heron).
Try setting the motherboard into AHCI mode rather than IDE mode (you should be able to change this under hard drive settings in your BIOS)
Also, the problem may be with your optical drive. Try swapping that out.  If you can't solve it from there, if you haven't already, try posting on the ubuntu forums.
Jul 26, 2008 | Excelstor Technology J880 Hard Drive
Computers & Internet Logo
41 people viewed this question
Top Intel Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Michael Thomas
Michael Thomas
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
