My wall safe is closed I have the correct code it flashes green but when I turn the handle/knob the safe door won't open. I'm not sure of my safe design# it was already installed in our house upon purchase. We've live here for 3 years and this happened one other time but with repeated tries it finally opened. This time I've tried without success.
SOURCE: Green proceed light goes on but door does not depress lock
I have a different model but I had the same problem. Called customer service and they had me push up on the handle and enter the code. That didn't work but then they had me tap the safe with a rubber mallet 5 times above the panel and 5 times to the right of the panel. That worked for me. Hope one of those works.
SOURCE: Garage door opener closes when closed
Try this: Loosen the chain enough that you can remove it from the sprocket above the motor. Now run the opener until the sprocket turns in the clockwise direction and stops. Reconnect the chain. This will get everything in sync and you will have to tweak the 'up and down limits' a bit to get it just right.
SOURCE: Upon initiating the door to
The question is located in the Riding Mowers & Garden Tractors section.
Also, what is the brand name and model # of the garage door opener?
To look up what the Diagnostic light flashing 12 times then pausing means, I need the above information.
Enter your code on the keypad located on the front of the safe. Some electronic digital safes require you to input a special character like "#" before and after your code. The safe should either beep, have a LED turn green, or display "OPEN" if you have correctly entered the code.
Turn the handle to the right within five seconds of correctly entering the code. If you wait too long, the safe will lock and you will have to enter your code ag
Open the safe with a key. Use your emergency key that came with the safe to open it if you forgot the code or if the batteries have died. Remove the key cover from either the handle or the control panel to reveal the lock.
Enter your code to open the safe.
Place the electronic digital safe into code reset mode. On some models you need to hold the last digit of the code or press the "*" button to get into code reset mode. Other safes require you to open them and press a small red button on the inside of the door.
Enter your new code on the keypad and press "#" to finish. Some safes may require you to press "*" or a letter to finish the code. If the safe requires it, enter the new code again to confirm that you entered it correctly.
Use your code to open the electronic digital safe's door.
Locate and remove the battery cover on the inside of the door.
Replace the used batteries with new ones. For most safes, this will require two or four AA batteries.
Test the batteries. Use your code while the door is open to test the batteries before closing the safe.
