Question about GE Refrigerators
Call GE to ask for repair manual.
call toll free in the United States 1-800-626-2005
I only found an owner's manual online, and put the comment above for the link.
Posted on Apr 10, 2018
SOURCE: Refrigerator is freezing
try cleaning out the coil....if you havent cleaned it dirt will block air flow causing erratic temps in the refrigerator section
Posted on Jul 30, 2008
SOURCE: Side by side GE refrigerator freezing food in refrigerator.
The unit is having a damper control issue. In the back of the refrigerator there is an assembly that is in the center at the top. It connects to the freezer side. The damper is broken, cracked or has an obstruction. Check this and see if it is the problem.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/robert_e97a69269ae71345
Posted on Jan 09, 2009
SOURCE: I have a ge profile side by side refrigerator.
First thing...Take a good look at all the door seals. If they let air and a lot of moisture in, that can condense and freeze causing your problem.
Second...Manualy defrost your freezer and see if the problem re-occurs. It may be that someone left the door open once and caused the icing.
Posted on Jul 18, 2009
SOURCE: GE build-in sideby side fridge problem
This is a common problem when the defrost condensate drain becomes blocked. Below is a link that tell more about what is happening. Sea Breeze
Posted on Jul 25, 2009
SOURCE: IS THERE ANY SITE THAT HAS FREE REPAIR MANUAL FOR
ready ? Number 1 thermistor is located against the back of a U shaped chanel atop the left side refrig shelf mounting bracket beside the refrig damper . #2 is located 1/2 way down on the refrig right wall with a 2 " oval covering . # 3 you only have if you have a quick chill at the lower right side in refrig section . # 4 is clipped atop of the coils inside the freezer section . # 5 is located slightly foreward of the drain pan inside of a small capsule at the bottom of the freezer section . There is a way to check all thermistors useing the touch control board , but that was not the question you submitted .
Posted on Aug 30, 2009
Testimonial: "you gave out very GOOD directions Thank you"
Jun 22, 2016 | GE Refrigerators
Oct 05, 2014 | Refrigerators
Aug 11, 2014 | GE Refrigerators
Jul 12, 2012 | GE Refrigerators
Sep 27, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Dec 10, 2010 | GE CustomStyle GCL22KGRSV Side by Side...
Feb 06, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Mar 01, 2009 | GE GSS22JEPCC / GSS22JEPWW / GSS22JEPBB...
Jan 08, 2007 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Mar 02, 2021 | GE Refrigerators
226 people viewed this question
Owner's manual but not repair manual found at link: https://www.myapstore.com/MarketingObjec...
