Question about Hotpoint Dryers
I took orange and red wire off the back of my hotpoint dryer and forgot wictch one goes to c and b on the back so my question is does the orange go9 on c or b
Posted by carl simpkins on
  • Steve Pack
    Steve Pack Apr 10, 2018
    Hi carl simpkins, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What is the model number and where do you live U.S. Europe
David Spradling
    Top Expert:
  • Hotpoint Master
  • 11,303 Answers
Check inside should be a schematic zip tied to wires
Posted on Sep 01, 2018
ray gallant
    Top Expert:
  • Hotpoint Master
  • 67,986 Answers
Does not matter with AC current . as long as you do not hook either to green
Posted on Apr 10, 2018
5 Related Answers
Anonymous
  • 209 Answers
SOURCE: hotpoint wireing not sure which wires go where
one of the wires will be the neutral and will have 3 ends to it (spades) all linked together (follow me)each one of the ends will go to one of the spades on each one of the solenoids (taps, now you will have a space on each solenoid to connect to the Blue generally indicated cold and Grey indicates conditioner, conditioner is generally the middle solenoid, if you follow the flow looking from above it goes furthest to the front of the washer (WMA models or later only) if the wires are as fixed lugs that is 2 wires are in a mold then just match the colours, the clue is on the back of the machine it also says C or H next to the respective solenoid, hope all is ok then
Posted on Sep 08, 2007
Anonymous
SOURCE: Need to plug wires back in
RED on J4-1,2
BLK on J4-3
YEL on J4-4,5
Posted on Oct 30, 2009
Anonymous
  • 145 Answers
SOURCE: orange wire
look in the wire schematics that came with the dryer or look them up online. They should tell you what that wire is for.
Posted on Apr 27, 2010
Anonymous
  • 145 Answers
SOURCE: timer
I have seen a similar question before. Look up the wire schematics and see what that wire is for. The sire schematics usually come with the dryer.
Pete Norton
  • 121 Answers
SOURCE: forgot which color wire connects
You need the wiring diagram to be absolutely sure.
Posted on Aug 02, 2011
I am replacing the heating element, and want to hook it back up the right way
WELL IS THERE TO RED WIRES AND AN ORANGE WIRE TO ELEMENT RED WIRE COMING FROM TOP WIRING HARNESS GOES TO THERMOSTAT ORANGE WIRE GOES TO OTHER SIDE OF THERMOSTAT AND RED WIRE FROM BOTTOM OF HARNESS GOES DIRECTLY ON HEATER
Jan 25, 2011 | Whirlpool Dryers
Orange wire
Apr 27, 2010 | Roper REX4634KQ Electric Dryer
Reconnect wiring on a Hotpoint VTD00 tumble dryer
most electric dryers have a wiring schematic on the back or inside on the back pannel of the unit it self . try too look for one there and it might help you out
Oct 30, 2009 | Hotpoint Dryers
Dryer gas ignites Runs for up to 5 minutes flame goes out
check the igniter to make sure it is glowing white and not orange. if it's orange replace it. you may also need the gas coils replaced.
Oct 16, 2009 | Hotpoint Dryers
I have a 30 amp conversion cord with 4 wires and 3 terminals. What wire goes where?
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power cord, take that wire or strap off the frame. (it can be discarded or better yet, in case this dryer needs to ever be converted back to a three wire cord) connect the frame end of the wire / strap to the center terminal of the power block. Now, Green (ground) wire goes to the dryer frame, White (neutral) goes to the center terminal, and the Red and Black (both "hot") wires go to either outside terminal. (one to each)
Oct 04, 2009 | Hotpoint TDC32 Electric Dryer
RED on J4-1,2
BLK on J4-3
YEL on J4-4,5
May 26, 2009 | Mackie SWA1501 Subwoofer
Hot point model nvl333eyoww will ot dry clothes
your dryer has a belt switch go here to see it www.repairclinic.com once there enter your model # and it will show you your parts
Mar 10, 2009 | Hotpoint NVL333EY Electric Dryer
Dryer heating element
To the heating element goes Red and Red with White.
To the Hi-limit thermostat goes Red with White and Black.
To the Thermal cut-off goes Black and Red.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 11, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
63 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
peter gittos
peter gittos
Marvin
Marvin
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
