Question about Kohler Home
My Kohler Whirlpool won't turn on and the on/ off button is not illuminating , I have power going to the unit
Posted by Christine Memet on
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
Sep 03, 2012 | Whirlpool WTW5550XW Energy Star Qualified...
Wirlpool bath pump doesn't stay on.
If this is a new unit you need to complain to whoever you bought it from. somehow it doesnt surprise me with the kohler name on it. I used to work for a company that sold mostly kohler stuff.
Apr 02, 2010 | Home
Flip up screen won,t illuminate. dark
if the screen needs to be wired to the dash light switch it will not change unless the lights are on, if the wire is disconnected it is possible to bypass it making the screen stay bright.
although it would seem more likely that the brightness could be adjusted on the unit settings or by a button on the unit itself
Nov 10, 2009 | Pioneer AVH-P5700DVD Car DVD Player
Motor not working at all. Won't even go on
a good electrican will check for power but may not be able to test a printed control board. Maybe simpler to get a spa repairman
Aug 12, 2009 | Kohler 1014-H2-96 Portrait 5' Whirlpool...
Kohler Whirlpool tub motor wont turn on
Kohler Whirlpool tub turns on and shuts right off. Reset gfi and motor turns on and shuts right off. Help
Mar 15, 2009 | Kitchen Appliances - Others
Heater doesn't work correctly
I think the pump is going out on reset or hi limit
Mar 13, 2009 | Kohler Riverbath Quadrangle Whirlpool w/...
Kohler whirlpool will not shut off and sounds like about to blow
Sounds as if you may need a new switch to turn the tub on/off. You can find one on our site www.uspartscenter.com
Feb 28, 2009 | Kohler 1221-H-0 Seadream 6' Whirlpool Bath...
II have a kohler jacauzzi baththub and it's not coming on. Help, we need to fix it because we're in the process of selling our home. We already checked the breaker in the basement. Thanks in advance.
There may also be a breaker close to the tub and a reset button inside of the unit. I would begin by opening up the base and looking for a reset button. good luck
Jan 18, 2009 | Kohler 1221-H-0 Seadream 6' Whirlpool Bath...
Kohler whirpool tub will not turn on
Here is the manual for the tub. The switch is an air switch with tube. You have to make sure the tube has no holes in it or replace it if you can. look on the manual it will help you out.
http://www.us.kohler.com/onlinecatalog/pdf/1010564_5.pdf
Dec 14, 2008 | Kohler 1263-96 Folio 5.5' Drop In...
Home Logo
425 people viewed this question
Top Kohler Home Experts
john h
Bill Johnson
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
