Question about Electrical Supplies
What causes rising speed fault when starting a kohler KD165 Generator?
Engine auto shutdown with rising speed detected on start up attempt.
Posted by waneta bitol on
5 Related Answers
CarlGehrke
Carl Gehrke
  • 169 Answers
SOURCE: kohler 12kw generator starts but shuts down after 3sec
Your gas pressure is too low and you may not have a large enough supply pipe. You need at least 10 inches of water column with the engine running to operate an LP vapor fueled engine. Because the engine is starving for fuel, its governor opens the throttle to WOT (so it goes to high revs) but there isn't any fuel to make horsepower with so the output voltage falls and the undervoltage alarm trips.
Carl
Posted on Dec 03, 2008
Anonymous
SOURCE: I have 16 hp Craftsman riding mower with a Kohler engine.
It may think you are in reverse and is killing the motor to keep you from backing up with the blade running. Look for switch that is telling it when you are in reverse, maybe it is stuck with grass or other debris. another possibility is that the blades are jammed and they are stalliing the motor. Mines stalls easily when cold.
Posted on Mar 12, 2009
mamicheddy
mamicheddy
  • 79 Answers
SOURCE: Hello, I have a Kohler Marine Generator that says OC on the menu when I try to start it. Any ideas?
OC stands for Over Crank. How long does it take before the genset starts?
Posted on May 07, 2009
Anonymous
SOURCE: Car cranks but won't start. Diagnostic code says
I changed all the parts I mentioned and finally I decided to try the crank shaft sensor and if that didn't work I was going to replace the cam shaft sensor. Luckily the crank shaft sensor worked but only after I replaced all the other parts. But at least now it finally started.
Thsank you.
Posted on May 18, 2009
Molson02536
Harvey N Tawatao
  • 3854 Answers
SOURCE: 97 Dodge Caravan Auto-Shutdown Problem
Been working on my dad's 97 Caravan longer then i can remember for things you mentioned and have been not able to get him to sell it.
I found that the electrical connections are prone to corrosion and have replaced lots of the wire and pin connection in the wire harness, thank god i have time on my hands.
The instrument panel where the wire harness connects, i found that the solder goes bad and i had to re solder the connector on the back side of the circuit board, where the harness goes so you need to remove the instrument panel from the dash,
Here is a link that can help you retrieve DTC codes and do research on your caravan. I'ld tell you everything what i needed to do to keep my dad's caravan running but that would be a novel. http://www.allpar.com/fix/stall.html
Good luck and keep me posted, glad to help you keep yours running too.
Posted on May 26, 2009
Generator starts before it gets upto speed the frequency and voltage lights flash and the generator shuts down within 30 seconds from start. What is the problem?
Mybe power from the commercial supply had failed . Or power surge occured and the genset detected power failure.
The other cause could be air bubbles in the gasoline.The genset may need bleeding to remove air bubbles in the gasoline.
Apr 05, 2017 | Speed Electrical Supplies
WHAT WOULD CAUSE A AUX FAULT ON A KOHLER GENERATOR MODEL 80ROZJ
Aux fault can be many things, if it failed to start you may get it. Try reseting and manually starting. See if it re-occurs while it is running or does it ever start and give error. I have seen this generator by a coolant level sending it is an auxillary fault
May 09, 2014 | Kohler Generator 30 Kw Nat Gas Or Propane...
Kohler 20kw RESA "invalid shutdown" fault
I have a Kohler 14Res and an error Invald Shutdown is indication and the engine is not crancking
Jan 30, 2013 | Kohler 20resa 20kw Home Emergency Backup...
Kohler 12RES only starts on second try
Check gas pressure. Oc is over crank. Means tried to start but did not.
Nov 25, 2012 | Kohler 12 kW Emergency Power System -...
Kohler 12 RES - Unit fails to start occasionally. Attempting a manual start by placing switch in run position, cause a loud click, but no cranking. The panel says CC. This morning I put a jump start...
I finally solved the intermittant starting problem on my Kohler 12 RES by replacing the strater and the starter relay. I was also experiencing the occassional OC indication, red blinking LEDs on the ATS, and intermittent non-starts during the weekly exercises. The problem happened during power outages a couple times also. If I flipped the start switch between auto and run quickly the generator would occasionally start. Once started, the generator runs fine. I ordered a new starter, which included the starter solenoid. By the way, don't worry about the genuine part thing..the old starter was a Delco made overseas. I ordered a new starter online for $85 (6744N) and it was indentical to the genuine Kohler starter. Replaced the starter and it improved the problem but did not totally solve the intermittent starting. Ordered the starter relay (GM49746) replaced it and the problem is solved.
May 09, 2012 | Kohler 12 kW Emergency Power System -...
I have a 2002 yukon xlt, today the battery light started coming on intermitantly and the battery started losing voltage, I pulled the alternator and had it tested at 2 different auto parts stores , both...
Is there B+ voltage on the heavy gage wire on the back of the alternator ? Possible blown fusible link. Plus the two wires in the connector go to the PCM - engine computer . One is the turn on signal ,the other is charge indicator control . Having the vehicle checked for DTC'S - diagnostic trouble codes should also be done .DTC P1637
The powertrain control module (PCM) uses the generator turn on signal circuit to control the generator. A high side driver within the PCM allows the PCM to turn the generator ON and OFF. When Generator operation is desired, the PCM sends a 10 volt signal to the voltage regulator via the generator turn on signal circuit. This causes the voltage regulator to begin controlling the generator field circuit. Once the Generator is enabled by the PCM, the voltage regulator controls generator output independently of the PCM. Under certain operating conditions, the PCM can turn Off the generator by turning Off the 10 volt signal on the generator turn on signal circuit. The PCM has fault detection circuitry which monitors the state of the generator turn on signal circuit. If the fault detection circuit senses a voltage other than what is expected, this DTC will set. The voltage regulator also contains fault detection circuitry. If the regulator detects a problem, the regulator will ground the generator turn on signal circuit, pulling the voltage low. This also causes the PCM to set the DTC.
Your best bet mite be to take it to a qualified repair shop.
Dec 28, 2017 | 2002 GMC Yukon XL
My Kohler 11RMY (40 amp) standby generator will not start
You should have two wire remote Start/Stop. It may need to be shortened in order to start.
Jun 06, 2010 | Kohler 12 kW Emergency Power System -...
1975, 7.5 Kohler marine genset, runs only with the reset depresed
Can't search for a manual without model, type, serial, etc numbers...
A few things to take a look at:
1) Oil level / pressure sending unit. This is normally bypassed as long as the start switch is pressed. When engine starts, and switch is released, engine will die if sending unit is defective, or you are low on oil.
2) Exhaust temperature sensors. Older units were notorious for burning these up.
3) Cooling Water Temperature sensor. These cause trouble often, but mostly due to water pump impeller being eaten away by galvanic action and not able to pump water as effecively. End result is water temp higher than normal, which trips the switch, which kills the engine.
4) Alternator (generator) output not as it should. If output doesn't rise to proper level within a few seconds of engine start, the engine will be shut down.
5) Choke not working as it should
6) Bad fuel, bad fuel pump, clogged fuel filter.
May 26, 2010 | Kohler Electrical Supplies
I have a Kohler 12RESM1 propane generator with oc/uu code
U need to make sure that the relay driving ur auto start stay closed all thru the crank cycle.
Feb 04, 2010 | Kohler 12 kW Emergency Power System -...
Generac Guardian 15 kw overspeed fault
Did you remember to set the overspeed shutdown threshold on the control board?
Apr 03, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Electrical Supplies Logo
66 people viewed this question
Top Electrical Supplies Experts
Marvin
Marvin
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
