Question about Asko Dryers
ASKO T712 dryer. How do you replace wires to control panel? Main wires are OK. There are two small wires, one black, one brown. They fell off. I don't know where they attach. a photo would help!
Posted by Louise Young on
5 Related Answers
worldvet
Glenn Rogers
  • 859 Answers
SOURCE: Trying to replace 3 speed ceiling fan switch
The black goes to the L connection the others are a guess. You can do this two ways. Connect the colored wires in any sequence and then see what switch sequence give you high and lowest, the other one will be medium. Once you determine that, mark the wires with a piece of masking tape as high, medium and low. Otherwise you connect them, turn power on and use a multimeter to see which color gives you the highest voltage and which gives you lowest. Since you aren't comfortable using live wires and a meter, go with the first option and use the process of elimination to find the wires giving you the speeds you need to find the highest and lowest. Next, you need to determine how your switch sequence works. First pull has to give you highest speed. so you may end up wiring them in reverse if your first attempt is backwards. There is a reason the first pull needs to be highest, it powers up the motor so you can then chose a lower setting. A low setting first will over tax your motor and wear it out eventually as it has to work harder at first.
Let me know if you need further clarification and perhaps this is all you need to get fixed.
Regards,
Worldvet
ps I checked on the Internet of a wiring diagram and I bet you did tok all to no avail.
Posted on May 27, 2008
Anonymous
  • 254 Answers
SOURCE: HELP!!! Help wiring new motor for CKL60-1
  1. This is what your wiring should look like if you are using two caps. then you should be using a potential relay as well. This is the diagram for using a potential relay. Hope it helps you.
Posted on Aug 28, 2008
Anonymous
  • 1122 Answers
SOURCE: hooking up the four prong cord to the dryer
this is the rule of thumb,white always goes on the middle terminal ,the 2 outside terminal wires it does not matter which side they are on,if you can see the red and black wire on the terminal block then match them up,the green wire gets mounted to the cabinet,you should already have a green wire to the cabinet so remove the screw and put both wires there and your done,let me know how you do-mike
Posted on Oct 15, 2008
Anonymous
SOURCE: Wires came loose of control unit from circuit
Rotate the iTrip AutoPilot FM Transmitter controller so that its buttons are facing up and its data cable is on the left side. The data cable wires attach to a row of contact points along the left side of the circuit board as follows (from top to bottom):
1 = Purple
2 = White
3 = Blue
4 = Red
5 = Black
6 = Brown
7 = Green
8 = Yellow
9 = <unused>
Posted on Apr 22, 2010
Anonymous
  • 259 Answers
SOURCE: I have a Maytag Dryer model # MDE5806AYW
http://www.apwagner.com/large_image_viewer.php?image=images/diagrams/00191/i385263.GIF
Here is the link to the wiring diagram for your dryer, I'm assuming you are looking for the wires as they connect to the incoming power cord? They appear to be the only ones with that specific wire color code.
Hope this helps!
Posted on Jul 14, 2010
Where is the fuse on thr asko t712 dryer?
Look in the centre of the back of the dryer for a black rubber seal and press the seal in until you hear a click (this may not apply to your particular model of ASKO dryer). If you are lucky the circuit breaker has done it's job and saved your dryer, otherwise it has been badly damaged and will need electronic repairs to the control board.
Sep 10, 2018 | Asko Dryers
I need to repalce the belt on an Asko T712 front loading dryer. Do I go in from the front or the back?
I took the top and back of my unit apart. Then from the back it is still not the eaisiet of tasks.
Oct 13, 2010 | Asko T712 Electric Dryer
Where is the heater located
Are you familiar with the location of the heater hi-limit for the Asko dryer ? If so, that is the location of the heater assembly, under that housing at the back panel of the unit.
**Turn off the power or unplug the unit from the wall before performing any service**.
If not, make access to the rear of the unit possible, slide it out or whatever the case may be in your situation. You`ll see the back panel has screws all around the perimeter, but also an alongated round cover with screws around it`s perimeter as well. The heater is enclosed in this housing as is the hi-limit reset-able thermostat ( covered by a round black button like rubber cover ).
**If your dryer isn`t heating, check the hi-limit first by pushing in the middle of it`s black rubber cover before dis-assembling your dryer too far.**
Hope this answer`s your question and help`s move you forward. If so please rate this info accordingly.
Thank`s for visiting "fixya" today for your repair inquiries and good luck.
macmarkus :)
Apr 07, 2010 | Asko T712 Electric Dryer
Will not dry after 2 hours
Hello. Actually this is not a ventless dryer, there is a vent hose whic typically comes with the appliance. If the appliance is not vented out-of-doors it should at least be vented into the room. Pull the dryer out from the wall so you can inspect the rear of it and you will see the vent hole. If need be, go to any hardware store and purchase a dryer vent kit.
Here is a clip from the Asko T712 literature.
Easy to install Simply plug it into an electrical socket and connect the ventilation hose provided.
Dec 19, 2009 | Asko T712 Electric Dryer
My dryer wont stay hot
Check for a faulty high limit thermostat. It is a small round black device mounted on a metal plate. It is usually mounted to the internal ductwork with two screws. It can be tested for continuity using a multimeter or ohm meter. It should have no continuity. If it has continuity, it is stuck open and is faulty. I am attaching a pic showing a thermal fuse and high limit thermostat for reference. Hope this helps and best wishes.
Aug 17, 2009 | Asko T712 Electric Dryer
Alarm F1 stoping dryer type T712, what the reason?
For information, behind front panel are optional hidden sensors and one of them had to be reset.
K,W.
Apr 14, 2009 | Asko T712 Electric Dryer
I need to know if a new Asko Dryer will stack with my old washer
The exterior size hasn't changed and the plug to run the washer is the same so I don't see a problem. A good retailer can check this for you , but I haven't seen any difference in the stacking kits.
Feb 12, 2009 | Asko T712 Electric Dryer
Dryers Logo
Top Asko Dryers Experts
Marvin
Marvin
Paul Carew
peter gittos
peter gittos
Are you an Asko Dryer Expert? Answer questions, earn points and help others
