SOURCE: I need to replace the
You will find compatible battery type at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
First, remove foil and cutter. Then remove the swivel frame by removing the two tiny screws. Then pop off the two screw covers on the bottom of the shaver and also the screws underneath. You can then gently pry the two halves of the case apart at the bottom to access the insides.
For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Testimonial: "thank you"
