Question about Westclox Audio Players & Recorders
Setting A Westclox 72020 Digital Alarm Clock with day, date, and temperature
Posted by Claudette Webb on
5 Related Answers
Anonymous
SOURCE: Westclox Monarch Alarm Clock - Model No. 90003
While holding down the snooze bar that says "ALARM" on it, hold down either of the "HOUR" button to set the hour when the alarm should go off or hold down the "MINUTE" button to adjust the minutes for when the alarm should go off.  Switch the "ALARM" to "ON" when done.
Posted on Sep 03, 2008
Anonymous
SOURCE: Westclox Travel Alarm
After selecting either TIME, DATE, or ALARM at the top of the screen, use the stylus to touch and hold the large time display. Hold it there for about 5 seconds and the clock will beep and the time display will start flashing. Then you can touch either the hours or minutes and it will increase by either 1 hour or 1 minute accordingly. When the DATE is selected, it shows the year in the large display. Again, holding the stylus on the year diaply for about 5 seconds will enter into the chqange mode. IN all cases, to exit the change mode simply select one of the other selections across the top: TIME, DATE, ALARM.
Posted on Sep 08, 2008
Anonymous
SOURCE: setting time and alarm clock for timex nature sounds clock
Hold the time set key in until the time flashes. Now let it go and use the tuning forward and back keys to set the time. I had the same problem because I continued to hold the timeSet button down while trying to adjust it. If you do, the forward/back keys have no effect.
Posted on Jan 08, 2009
Anonymous
  • 3 Answers
SOURCE: Date keeps changing a week forward after setting time
A possible solution to this issue could be changing the automatic update of time and date. If it's currently switched on on your phone, try switching it off. And if it's already off try switching it off.
Here's where to find the setting: Menu >> Applications >> Clock >> Options >> Settings >> Automatic time update
For more info, check the (English) N79 manual on page 147
Posted on Jun 14, 2009
Leobreaker78
Charles Luhrs
  • 5 Answers
SOURCE: I have a westclox atomic alarm clock - model #700...
I have the same alarm clock the damn thing gives me a heart attack when I wake up. All in all I have the instructions for your clock.
Simple on the back of the device there are five buttons hold down the one that is labeled mode/set then the display will flash use the oC|oF/Up key or Wave/Down key to change the keys and the mode/set the to move between each field.
If you press (not hold) the Mode/Set key you can change the alarm, change the numbers using the degreeC|DegreeF/Up or Wave/Down key to change numbers accordingly.
To turn the alram and snooze function on or off press the Alarm/on\off key.
What I just said may sound complicated but of you press the buttons as I told you then you should have no problems what so ever.
Posted on Jun 03, 2010
The alarm won't work on my nearly new moonbeam clock
go through the setting for alarm procedures as there may have been glitch that dropped the setting off
How to set alarm for Westclox 47550 Quartz?
Hi, A 8 year old can do this. On the back of the clock there should be 2 round turning nobs. 1 is for to set time (min...) 2sec is for to set timer for that hour...usually is a smaller hand on face of clock.
select hour to wake up at and set alarm Button. This is only basic set up.
How do i set year on westclox 70034 alarm clock?
You need to make certain that you have set the year right, otherwise it will show the correct day for say 2011, rather than 2013.
9helpful
Setting the time on ascot projection alarm clock
Ascot AUPWE10 Projection Alarm clock. To change the main time and date. Push the Mode button until the temperature display is shown at the top. Then hold the mode button in until the the day function flashes down the bottom. Move to required field by pushing the mode button again. Adjust date and time displays using the arrow keys.
Westclox model LTX271 instructions for setting day
mcdevito75 here, The stem on your westclox has 2 positions, First pull the stem out to set the time of day, keep cycleing the watch until you come to 1 day before the day you want. NOW! push the stem back in. NOW! slip a finger nail just under the crown and gently, gently kift the crown to it"s first position, it may take a little practice so be patient, once in it's first position you can change the DATE easily, change the DATE to 1 DATE before the DA you want, push the syem back in and pull the stem back out and set the day/date and time of day. Your watch is set and will change on time a little past mid nite.
Digital clock gains time
digital clocks work of the frequency input of the power source so it is possible to have it adjusted by a technician
like fine tuning a radio frequency there may be a pot that can be tuned to mains frequency exactly
talk with technicians in radio or tv shops or possible some jewellers who work on electric clocks may help
25helpful
Top Westclox Audio Players & Recorders Experts
nexrad_chris
Ngoro
Are you a Westclox Audio Player and Recorder Expert? Answer questions, earn points and help others
