The problem could be a damaged temperature sensor or loose wire to the temperature control F11 is the error for the control board keyboard being shorted out. replace the control board and keypad. ... The F30 error code means the temperature sensor probe is open.
Kenmore 790 Model Induction Cooktop Error Codes Sears PartsDirect
Take a look at this link ... for model 790 it indicates that error 35 is: Improper power supply voltage (low voltage) or failed wiring connections
Check: Disconnect power. Check the power supply wiring. Have an electrician check the supply voltage. If the connections are good and the voltage is normal, the main power control board or filter control board is defective.
So it may need a new control board...
The E3 F1 error code indicates a Fuel Type Failure. The control board on the Kenmore ranges and ovens that use this error code can detect whether the control board programming is set for electric (E) or gas (9). The troubleshooting for this failure is to unplug the range or shut off the breaker to completely kill power for 30 seconds. After powering the unit back up, hold the CANCEL and START/ENTER keys for 5 seconds. You should see "E" for electric or "9" for gas. If you have an gas range and the "E" is showing for electric, then the electronic oven control board will likely need to be replaced. The opposite is true if you have a gas range or oven.
The "F11" fault code indicates a shorted button on the electronic oven control. This means the oven control board will likely need to be removed and replaced. You could disconnect power, wait 30 seconds and reapply power. If "F11" returns upon power-up, replace the electronic oven control board (EOC). but if i had your model number i could nail it right on the head with a fix...
Hi. Unfortunately, this code is indicating that your control board is severely damaged. This will require you to have this damaged control board replaced, asap.
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure. Select the 'cancel' function and wait 60 seconds. If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&!!
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric) F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper) F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool) F1-E0 EPROM Error - Electronic Range Control (ERC). F1-E1 EPROM Error - Electronic Range Control (ERC). F1-E2 U/L ERC Errors - Electronic Range Control (ERC). F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric- “9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire) F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error. Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
The F1 and constant beeping is an error code indicating that your electronic control board (clock/timer) is defective. The fault cannot be reset and the control board must be replaced. This can be an expensive repair if your range is no longer covered by a warranty or service plan. The cost to buy a new control board can be in the neighborhood of about $200. Sorry...but I do hope this helps you.
