Question about Sport & Outdoor - Others
Can I get replacement poles for a Timber Creek Tellico 7x7 dome tent
Posted by Mary Anne Rehm on
john h
    Top Expert:
  • 23,401 Answers
Fixya doesnt sell products notify manufacturer seller or online search
Posted on Jun 24, 2018
1 Related Answer
Tom Chichester
  • 55379 Answers
SOURCE: how to assemble a Timber Creek Tellico Dome Tent
Can Timber Creek help with instructions?
Posted on May 09, 2013
I need to replace tent flys for a timber creek 8 x 10 and a 7 x 9
any upholsterer or shop that makes tents, shades or awnings can do this for you
check the trades directory or google-- tent repairs-- for a business near you
Nov 27, 2016 | Camping, Backpacking & Hiking
How do I assembly the tent
Step 1 Remove the tent, poles, stakes and tent rope of the dome tent from the Northwest Territory sack. Locate a large flat area and remove any sticks and rocks from the ground. Step 2 Lay the tent fabric on the ground with the bathtub style floor face down. Pull the corners of the fabric tight and rotate the tent so the door is facing in the direction you want. Use a hammer to stake the corners in the ground. Step 3 Assemble the two long poles to their full length. The pole segments are connected by chords and will easily snap into place. Slide one pole through the diagonal sleeve on the top of the tent. Slide the other pole through the other diagonal sleeve to form an "X" with the poles. Step 4 Place the end of each pole in the corresponding grommet. The poles will bend and the shelter will be erected. Step 5 Assemble the two small poles. Slide one pole in the doorway sleeve and the other in the back window sleeve. The poles will bend slightly to create a rain peak on the door and window. Step 6 Pull the doormat tight and pound stakes through the loops on each corner. Pull the tent rope tight on the back of the tent and pound a stake through the rope loop to anchor the tent to the ground.
May 31, 2015 | Northwest Territory Sierra Dome Backpack...
Timber top 3 man dome tent set up
How do I put up my timber top tent 3 men with just the color of the poles
Oct 27, 2013 | Sport & Outdoor - Others
Tent replacement parts
Tent-Parts.stuccu.com. This is only one place you can get replacement parts for tents online. This one should be a good starting point.
Oct 03, 2013 | Timber Creek Camping, Backpacking & Hiking
Swiss Gear Tent - Broken Poles SG33071F
Take a look on amazon for replacement. here: Amazon com tent poles. I hope this was helpful. Cheers
Aug 24, 2009 | Wenzel Swiss Gear Grand Lodge Cabin Dome...
Tent
Well, you should have Three (3) longer poles and Two (2) shorter. Two (2) of the longer poles will be the basic construction poles. They will basically make an "X" across the top of the tent making the four courners of the tent. The other longer pole with also go across the top of the tent and right through the "X" made by the other two (2). This will push out the sides and make is "dome-like".
The two (2) shorter poles will go on either side of the enterance. These will hold up the sides of the tent to give you more volume space on the inside. Not exactly nessasary but if you want more than one or two people to fit inside, you'll need these.
Hope I helped.
Oct 14, 2008 | Sport & Outdoor - Others
Sport & Outdoor - Others Logo
300 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Tom Chichester
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
