Question about Magic Chef Refrigerators
Magic Chef Model: mcwbc77dzc Not cooling. Need help identifying a part.
After a recent power outage my beverage center will no longer cool. I have verified the following: Compressor is coming on and measured ok. Compressor fan is on. Cooling fins are free of dust Temp sensor is working measured resistance. I hear 3 clicks when I first plug in the cooler. These clicks are not coming from the compressor start relay. They are coming from a different relay that has 2 wires going to it directly connected to the main PCB. There is a brass line the is routed through it. I am assuming this is some sort of pressure valve that allows Freon to flow. Does anyone know the official name of this and where I can find one?
Posted by Chris on
5 Related Answers
MARK FISHER
  • 87 Answers
SOURCE: U-Line no longer cooling
This sounds like the thermostat is the problem. I wouldsuggest touching the compressor at the back of the unit to see if it is hot or cold. If it is hot then you have probably have power down to the compressor, if it is cold you could (if capable) bypass the thermostat to see if it kicks in. Hope this helps.
Posted on Aug 26, 2007
Anonymous
  • 619 Answers
SOURCE: Hot Compressor, no Cooling
If you have clamp tester / read the label of the compressor how many amphere register give allowance 5 amphere during testing time if register for example 3 to 5 amphere the label is 3 amphere is good the compressor / but it will register 0.5 or 15 amphere or up the compressor is badly replace.
Posted on Jan 08, 2008
Ronnie Houston
  • 2920 Answers
SOURCE: Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
Posted on Aug 27, 2008
Anonymous
  • 702 Answers
SOURCE: Cooling fan wont work
The water temp sensor is located near the thermostat housing. This sensor is what tells the ECM to turn the fan on/off. The water temp sending unit is located near the same area. You know you have the correct sensor is because the water temp sensor has a 2 prong plug. The water temp sending unit only has 1 prong.
Posted on Sep 27, 2008
Macmarkus
Mark MacDonald
  • 2605 Answers
SOURCE: Maytag refrigerator isn't cooling
Hi ****, Based on the discription you've provided it sounds like either a faulty start relay or the compressor is seized. If you have a multi- meter you can check the compressor to see if the windings are ok. Unplug the fridge. Remove the panel at the back down at the bottom. This should gain you access to the compressor. On the side of the comp. will be the start relay/overload assembly. Pull off the relay & overload and you'll see 3 pins in the form of a triangle. With a meter measure between any 2 pins at one time, going between each pin with one remaining on a "common" pin. You'll want 3 measurement's, similar to this example- 6ohms, 3ohms, and 9ohms. On some meters you may simply get a reading of "0" ohms, as long as the needle moves off of "infinity" which would indicate an "open" winding=not good ! If following that, the readings are good, purchase a hard start kit. Part # HS410 also known as a 3in1 starter kit. This will start it if it's not seized also known as a "locked rotor".. You can find them at most brick & mortar appliance parts locations or on-line vendors. The package contains info on how to connect it. If that doesn't yield any results moving forward, let me know we'll go from there. **I suggest you phone Whirlpool customer support first though ( they own Maytag ) as they recently had a massive recall regarding the starting device of many compressor's and you may find your's to be included therefore have it repaired at no cost.** they will know by your model and serial number or if that isn't clear the number on the compressor. Good Luck Thanks for visiting "fixya", please take a second to rate my solution and leave a comment/testimony to it's helpfulness. macmarkus :)
Posted on May 02, 2010
I have a beverage air MM14GE cooler that hasnt been on for over a year when i plug it in it turns on but doesnt cool, what can be the problem?
Verify that the compressor is actually running. You should feel it vibrating. If the compressor runs with no cooling most likely the refrigerant level is low.
Oct 12, 2013 | Beverage-Air Refrigerators
Not cooling
You can ohm the compressor to see if it is shorted but if the compressor is running it cannot be the overload or relay , if not running sometimes you can pull the relay and shake it if you hear any rattling in it it is bad
Apr 01, 2013 | U-Line 1175BEV Beverage Cooler
Refrigerator overload protector intermittent
To be short, the only thing in the machine that really has the capability of causing that is the compressor. Its got a floating short in and when it makes contact it trips the outlet/breaker. Check for any exposed wires just to be sure but I'm pretty certain that the compressor is the culprit and either it or the machine needs to be replaced or a proffesional sercvice tech called.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 28, 2012 | KitchenAid Refrigerators
Should we replace switch.
Many times the oils in the fan motors gum up and solidify after an extended shut down. Check that the fans are running. It's doubtful that in this case the switch is at fault.
Jan 08, 2018 | Avanti (BCA5105BG) Beverage Cooler
What does the overload relay look like a Beverage-Air MT27 Beverage Cooler Commercial
Normally thermal overloads have a button like appearance on the compressor. Designed to open circuit when temp has caused distortion to the bi-metal contacts. Upon cooling will close again. Disconnect power before checking continunity on the overload terminals.
Sep 27, 2011 | Beverage-Air MT27 Beverage Cooler...
I have a fairly new True tbb-2gs which is on a dedicated 120V/15A circuit...has had problems in past with condenser cycling. That problem went away after unplugging and replugging the cooler back into the...
You have to verify that the compressor is running. Don't assume that it is just because the fan is running. the compressor may not be running. If compressor is running, good possibility that it is low on refrigerant. Most common and obvious.
Aug 18, 2017 | True TBB-2G-S Stainless Steel Beverage...
Unit will not cool down.
it sounds bad but measure for power on the compressor if power compressor is damaged if not check thermostat or pc board if it have one
May 30, 2009 | Refrigerators
No longer cools.
This refrigeration system may be under extended warranty.
Otherwise check the compressor start relay for loose or burned contacts.
Mar 08, 2009 | Avanti WC494D Compact Wine Cooler Beverage...
GE Monogram Bev Center no longer cooling
Depend how old it is, Monogram does have a better warranty then regular appliances, sounds like it may have a bad power supply board in the back. It may have a compressor problem but the circut board  is more likely. It would probably be worth  having a GE tech to come and give you an estimate a the very least. Only because if you purchase the new board and install it, most places will not accept returns on electronic parts. Hope this helped.
Nov 14, 2008 | GE ZDBR240PBS Stainless Steel Beverage...
I have a BM23 Beverage-Air kegerator. It was working great until a blackout last week. I had a surge protector on the unit, but ever since then, the temp. would stay around 48-50 degrees. I had an...
electrician do one thing, electricity. If the unit cools, the compressor is running. a power outage should not put the compressor in a "Weaken" state. I would check the starting components. don't overlook your surge protector causing a voltage drop. try running the unit without the protector.
let me know if I can be of any further help.
Mar 14, 2008 | Beverage-Air BEVBM23 Commercial Beverage...
Refrigerators Logo
2,387 people viewed this question
Top Magic Chef Refrigerators Experts
Marvin
Marvin
Lawrence Oravetz
Vernon Taylor
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
