Question about Kenmore Dryers
My Kenmore dryer is not heatting up to dry - Kenmore Dryers
Posted by Jeffery Parker on
5 Related Answers
Anonymous
  • 525 Answers
SOURCE: Kenmore dryer
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information
http://www.repairclinic.com/0088_8_1.asp#Level1_2
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 20, 2008
docjohn174
john gagnon
  • 943 Answers
SOURCE: Kenmore 80's series dryer
HI thanks for the question. you said it took 3 or 4 hrs to dry a load. check the venting its cheap . clean all venting. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 11, 2008
Anonymous
  • 19 Answers
SOURCE: kenmore dryer 400series electric not gettin hot enough to dry
you might have a open heating element. ohm out your heating elements.
Posted on Feb 21, 2009
James Chandler
  • 686 Answers
SOURCE: Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Posted on Apr 06, 2009
milten1
milten1
  • 1304 Answers
SOURCE: my kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Posted on Oct 05, 2009
My kenmore Electri Dryer is humming while drying.
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.hope this help you out sincerely D.Jones
Jun 08, 2010 | Kenmore 64672 Electric Dryer
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
Gas Dryer drying clothes cold, no heat...
if it heats for a while and then no heat you have bad gas coils,when the coils are on there way out they work until they heat up then they cut out,see if you have heat when the dryer is cold,if it is change out the gas coils
Jan 25, 2010 | Kenmore 63942 Dryer
Kenmore elite 110 62974100, it heats up and the
kenmore dryer elite he model 110- runs but has no heat
Oct 08, 2009 | Kenmore Dryers
Dryer no longer has heat to dry clothes
The element gets brittle and breaks. The element is in the rear of the dryer under the dustcover.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 06, 2009 | Kenmore Dryers
Kenmore dryer 400series electric not gettin hot enough to dry
Feb 20, 2009 | Kenmore 62602 Electric Dryer
Kenmore 90 Series Dryer will not DRY
first check the vent outside to see if it is blowing air out strong, then check for heat.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
110 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
