Pride Mobility Products Go-Go Elite Traveller Scooter - 4 wheel w/12 AH Batteries & Charger + Flat Free Tires - Silver Logo
J
June Simmons Posted on Apr 09, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I check if there is a short in my battery pack on my pride go go elite please
Jeff Bird
Level 3:
  • Pride Mobili... Master 1,348 Answers
  • Posted on Apr 10, 2018
Jeff Bird
Level 3:
Answers
1348
Questions
0
Helped
363399
Points
4615
Hi a load tester will give u an accurate reading on there condition available on E/BAY COST APROX $35 ...test one battery at a time tester is 12 Volt :::::With a car battery u can check each cell separate with a Hydrometer..your batteries r sealed : u can't use one .cheers
How can I check if there is a short in my battery  - img_20180118_224641092-ajcfbg21rb4rb1cu3zartkut-4-0.jpg
1 Related Answer
gewiz
Rob Hill
  • 1480 Answers
  • Posted on Dec 25, 2009
SOURCE: my battery pack on my fold n go has a short and
hi, ok now you need to check your wiring within the battery pack ,
If there are two batteries, you need to make sure that negative wire of one battery connects to the positive of the other battery,
now use the postiive and negative battery connections to connect to the scooter , that will give you your 24volts,
battery 1 connects battery 2
== 24Volts
use the + of battery 1 & - of battery 2 to connect to the scooter.
Regards
GeWiz.
Testimonial: "Thank you for answering. "
I got my battery pack off my Gogo Traveller Elite scooter. But the batteries are encased in plastic and I don't see a way to get them out. Help?
Turn the battery pack up side down and you will see holes around the outside of the case. With a long (12") Philips screw driver, remove 8-10 screws. carefully turn the pack back on it feet and the lid will come off. Be careful with the wires inside the battery pack and make a note of where they go.
Battery not charging fully go go elite scotter
hi, And you're sure the charger's okay ? , check the fuse located within the battery pack ...
Regards
Rob
www.gewizrepairs.co.uk
Go go elite not charging fully
Regards
Rob
Pride Elite Traveler Plus occasionally stops and flashes eight times. Turning off and on corrects for a short time.
Hi, right it normally one of two things:
1. the connection to the rear axle, remove rear axle and clean the four connectors, gently, make sure there is a good contact.
2. The connection of the battery pack to the frame, again clean and make sure there is a good connection.
Regards
1helpful
Battery stuck on Pride mobility scooter
Hi. There are no locking devices on the GoGo Elite Traveller series of scooter. The Battery pack simply lifts off. However, they can be very tight and sometimes require a sharp tug upwards to remove them.
Hope this helps.
14helpful
4answers
We have a 11 month old elite traveler scooter. The battery will not take a charge. We have had no previous problems. Any suggestions?
I just fixed this problem in a Go Go Elite that was less than 6 months old. We would plug in the charger and the "charge" light would not turn on, just the "power light" I took out the battery pack (check manual for instructions), removed the cover (8 philips head screws) and checked the voltage on the two batteries. One read 4.5 volts and the other 4.7 volts. They should both read at least 11 volts, ideally 12 volts. Evidently the Pride charger will not work if it detects that the batteries are too low. So I took out one battery at a time and connected a 12 volt auto trickle charger to it for 3 hours on each battery. Checked voltages and it brought them back up to 11.5 volts. I reinstalled the battery pack and then connected the Pride charger and THEN it showed a "Charge" light. I left the pride charger on for 12 hours and it brought it up to full charge.
Advice: Don't let your batteries get too low or the factory charger will not work.
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
