Question about Measuring Tools & Sensors
Isn't there a button to press the C and F on it that you press once to change?
I could not find an exact manual using http://www.google.com to search.
I found links to manuals that may be helpful:
http://jlrgear.com/wp-content/uploads/2017/06/SMART-GEAR-Weather-Station-STG-5939-KB.pdf
https://www.manualslib.com/manual/841274/Jlr-Gear-Smart-Gear.html?page=4#manual
JLR Gear Smart Gear User Manual Weather Forecast Icons Specifications...
Posted on Apr 09, 2018
SOURCE: Getting the clock off military time
With the sytem off, hold down the Alarm Setup button and the On/Off button to switch between 12 hour (AM/PM) and 24 hour (Military) time. If you need the manual go to
http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/guides/music_system.jsp
Posted on Dec 06, 2007
SOURCE: How do I change my whirlpool oven back to Farenheit instead of celcius...
its in your manual, did not give model number so i looked up anyone. if this does not work you can enter your model number here for a copy of user manual
http://shared.whirlpoolcorp.com/product_literature/search.jsp
To Change: Press and hold CUSTOM BROIL for 5 seconds. A
tone will sound and “C” will appear on the display. Repeat to
change back to Fahrenheit.
Posted on Nov 07, 2008
SOURCE: RF-Tech 433 MHz Problem
I have the instruction manual, send me a mail: [email protected]
Posted on Jan 30, 2009
SOURCE: How to set the time on Athletic Works watch
Press and hold the lap/reset button for at least 5 full seconds. You should see the word "SET" appear in the dispaly. Push the Mode button to change from alarm to date to month, time, etc.. Use the start/stop button to change the numbers.
Posted on Jul 13, 2009
SOURCE: have ds time from military to regular
you have to go to the main screen then at the bottom of the screen there will be a small DS click that and you will hit the menu
Posted on Aug 09, 2009
I own the same STG-6083-KB weather station. To switch between celsius and fahrenheit, press and release the DOWN button on the back of the indoor unit. This will toggle between celsius and fahrenheit when pressed. To toggle between regular and military time, press and release the UP button on the indoor unit.
