Question about Toshiba Computers & Internet
How to remove built in bios password on toshiba equium A100-338?
Posted by Nestor Lampasa on
5 Related Answers
Ekse
  • 13434 Answers
SOURCE: entered built in HDD1 user password
Hello
as the bios was reset the harddrive password was removed from the bios memory.
To get the password unlocked you will need to remove the harddrive from the laptop, buy a adapter so you can connect it to your pc and then do a few things Il tell you about later if your going to do it.
otherwice you can take the harddrive to a shop to be unlocked / reset to defaults.
Posted on May 10, 2008
Anonymous
  • 32 Answers
SOURCE: i forgot bios password on
  Inorder to reset the password, you must open the case,  and on the Motherboard there is a round battery. Its the size of a nickel.  In some cases you can just remove the battery and wait a few seconds and then replace it.
  Another alternative is to short some pins that will clear the bios password.  In close proximity to that battery you should find a set of pins. Normally there are 3 pins together and there will be a jumper on one end of the 3 pins. What you have to do is to remove the jumper and move it to the other end of the pins. In other words if the pins are labeled 1-2-3 and right now there is jumper on 2 and 3., Then you will remove the jumper from there and place it on pins 1 and 2.    Once doing so will reset the password on the bios.  Wait a minute and then replace the jumper on 2 and 3. And then you should have your problem resolved....
                                                 Joe  < Data Miner >
Posted on Nov 01, 2008
RALilja
Richard Lilja
  • 401 Answers
SOURCE: toshiba SPM30 bios password remove
All you need to do is open one of the covers on the backside of the laptop and remove the CMOS battery (it looks like the size of a quarter) for a few seconds, then place it back into it's holder and put the cover back on. You can then power up the laptop and then re-set up all the settings in the BIOS in order for the laptop to work correctly as all previous settings have been forgotten including the password.
Good Luck!
Rich Lilja
Posted on Jan 17, 2009
Anonymous
  • 10406 Answers
SOURCE: how to remove bios password for Toshiba Satellite A200
If you know the current password, use it to enter BIOS SETUP.
Then, type a "blank" ("space-bar") as the "new" password.
If you don't know the current password, you're stuck;
this is a "security" feature to prevent a stolen laptop from being used by the thief.
Posted on May 27, 2009
Anonymous
  • 5 Answers
SOURCE: need to unlock phoenix bios password for toshiba satellite a135-s4527
remove the keyboard the mobo battery is there you need to unsolder one end of it, lift the leg, and turn it on that way for it to clear.. you will have to resolder once done.. have the skills or find someone that does... and you're set..
Posted on Aug 07, 2009
How to remove bios password
enter the bios using password - go to security page and remove password by entering current password then press enter 2x - save changes to bios then exit.The password is now removed.
For unknown bios you will need to take it to a Toshiba service center or search for bios removal proceedures available for your model.This video may help.Cheers
Remove BIOS PASSWORD Toshiba Satelitte 110 149
May 16, 2014 | Toshiba Equium A110-233 A110-252 A110-276...
How do I fing toshiba A60 equium password
pull the battery out and leave it out for a few minutes and then put it back in - if you can reach the bios then reset optimum settings - if there is a windows password then reformatting will get rid of that one.
May 16, 2010 | Toshiba Toahiba Satellite A60 A65 Series...
Ive got a toshiba equium laptop bois password
Your BIOS password can only be removed if you can open the bottom plates and remove the button cell for a few minutes and reinsert it and close all plates and boot up. Also promise not to use passwords in future as we all tend to forget them sooner or later.
Nov 17, 2009 | Computers & Internet
My toshiba equium just wont except the main password, cant reboot..cant get into bios
At this time you need to cleat the BIOS password first so that you can get into BIOS. To cleat the BIOS password you need to open your laptop you just remove the battery first. Remove the screw and open the back cover. Locate the CMOS battery, all password are stored in CMOS memory.
Remove the CMOS battery to clear the stored BIOS password, Or you can remove also the CMOS jamper near the CMOS battery and turn on the unit with in 10 second and turn off. Reinsert the jamper. Now the BIOS password are already clear you can get now in BIOS to change some settings. Good luck
Oct 08, 2009 | Computers & Internet
How to remove bios password for Toshiba Satellite A200
May 27, 2009 | Toshiba Satellite Pro A200-EZ2204X...
Toshiba equium 2000 bios power on password clear
1. Turn the PC off.
2. Unplug power.
3. Open case (Using phillips screwdriver)
4. Locate Bios Battery (Little silver disk)
5. Remove battery for 30 seconds.
6. Replace battery and case.
7. Boot into the Bios and see if it cleared the Password!
This only works for 90% of desktops.
As for laptops you usualy need to contact customer support.
Apr 21, 2009 | Computers & Internet
Bios password
Remove the battery. Short the two jumper (or the two battery clips if you can find it) . Replace the battery and the password will be no more.
Jan 19, 2009 | Computers & Internet
Unlock bios password
i have forget my bios password please help me on Hasee laptop
Nov 20, 2007 | Toshiba Satellite Pro M10 Notebook
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
k24674
Michael Thomas
Michael Thomas
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
