Question about Toshiba Computers & Internet
How to remove built in password on toshiba equium A100-338?
Bios version 5.10
Posted by Nestor Lampasa on
How to remove bios password
enter the bios using password - go to security page and remove password by entering current password then press enter 2x - save changes to bios then exit.The password is now removed.
For unknown bios you will need to take it to a Toshiba service center or search for bios removal proceedures available for your model.This video may help.Cheers
Remove BIOS PASSWORD Toshiba Satelitte 110 149
May 16, 2014 | Toshiba Equium A110-233 A110-252 A110-276...
How do I fing toshiba A60 equium password
pull the battery out and leave it out for a few minutes and then put it back in - if you can reach the bios then reset optimum settings - if there is a windows password then reformatting will get rid of that one.
May 16, 2010 | Toshiba Toahiba Satellite A60 A65 Series...
Ive got a toshiba equium laptop bois password
Your BIOS password can only be removed if you can open the bottom plates and remove the button cell for a few minutes and reinsert it and close all plates and boot up. Also promise not to use passwords in future as we all tend to forget them sooner or later.
Nov 17, 2009 | Computers & Internet
My toshiba equium just wont except the main password, cant reboot..cant get into bios
At this time you need to cleat the BIOS password first so that you can get into BIOS. To cleat the BIOS password you need to open your laptop you just remove the battery first. Remove the screw and open the back cover. Locate the CMOS battery, all password are stored in CMOS memory.
Remove the CMOS battery to clear the stored BIOS password, Or you can remove also the CMOS jamper near the CMOS battery and turn on the unit with in 10 second and turn off. Reinsert the jamper. Now the BIOS password are already clear you can get now in BIOS to change some settings. Good luck
Oct 08, 2009 | Computers & Internet
How to remove bios password for Toshiba Satellite A200
If you know the current password, use it to enter BIOS SETUP.
Then, type a "blank" ("space-bar") as the "new" password.
If you don't know the current password, you're stuck;
this is a "security" feature to prevent a stolen laptop from being used by the thief.
May 27, 2009 | Toshiba Satellite Pro A200-EZ2204X...
Toshiba equium 2000 bios power on password clear
1. Turn the PC off.
2. Unplug power.
3. Open case (Using phillips screwdriver)
4. Locate Bios Battery (Little silver disk)
5. Remove battery for 30 seconds.
6. Replace battery and case.
7. Boot into the Bios and see if it cleared the Password!
This only works for 90% of desktops.
As for laptops you usualy need to contact customer support.
Apr 21, 2009 | Computers & Internet
Bios password
Remove the battery. Short the two jumper (or the two battery clips if you can find it) . Replace the battery and the password will be no more.
Jan 19, 2009 | Computers & Internet
I need to remove my bios password
You can try the old parallel port dongle trick.
Do a search on google for the Toshiba Password Removal. If you are enclined enough you can build your own parallel port key that will wipe the password out.
If you would rather buy a premade port key, search on eBay for something like this -
http://cgi.ebay.com/TOSHIBA-Laptop-Parts-BIOS-Password-Removal-Reset-Key_W0QQitemZ260176556199QQihZ016QQcategoryZ31529QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I found a schematic once online, a long while back when I had the need, and built my own out of spare parts in my shop. Worked great... only had to use it once for a customers laptop. But I still hang on to it just in case someone else comes along. There is also a USB version I believe.
Oct 25, 2007 | Toshiba Satellite R10-S802TD Tablet PC
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
k24674
Michael Thomas
Michael Thomas
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
