Question about Yes Televison & Video
Dose the led change color for wall charger model NS-MAC4U6NW yes or no and if so why ?
Posted by Eleafar Xelhua on
ray gallant
    Top Expert:
  • Yes Master
  • 67,876 Answers
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
Where is the earth return/ relay for the air con on my stx 550 ?
Chornic USB quick charge 2.0 charger,you can get 75% power from empty in 30 minutes. It also charges your non-QC2.0 devices at up to 2.4 amps.ideal for travel use. Chornic Quick Charge 2 0 2port QC2 0 4port USB Charger 5V 9V 12V 60W USB...
Nov 30, 2016 | Cars & Trucks
Insignia ns-55l260a13 does not power on. Power led blinks 5 shorts, pause, 2 shorts and stays on. Screen blinks and nothing else happens afterwards.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 23, 2016 | Ideal Sales New Insigniatm - 55 Class -...
Color setting
Refer its user manual for details. If you don't have the manual, try this link to download it. http://www.manualslib.com/manual/411406/Insignia-Ns-19e720a12.html
Dec 01, 2013 | Insignia NS-24E730A12 24" Class LED HDTV
Lights do not come on charger base
Same thing happened to me recently. The charger (wall transformer) is bad, there is little voltage coming out of the charger base. The circuit inside the base is simple rectifier with LED. Mine is fried from my experiment. If anyone has the resistor R1, R2 values or colored pictures to show the color bars would be helpful.
I thought mine was 52 ohms and 100 ohms respectively...but that doesn't seem right.
At any rate, a simple 14-15VDC 200mA charger could replace the adapter/circuit board altogether.
Jan 12, 2011 | Black & Decker 14.4 Volt Battery Charger...
NS-DCC5HB09 High Definition Flash Media Camcorder: mine wont turn on and i dont have a charger!!! Hel...
You should be able to recharge this unit by connecting to your PC and charging through your USB connection.
If your battery is faulty or unable to recharge, here's a replacement battery that's available:
http://bestbuy.partsearch.com/GetModel.aspx?MfgName=Best+Buy+Company+Incorporated&BrandName=Insignia&ModelNumber=NSDCC5HB09&Page=1&SortBy=brandname&SortDirection=asc
Just about any AC to USB charger will work to recharge this unit, so if you have an iPod with the iPod wall charger, use the correct USB cable with the wall charger and you will be able to recharge the battery in the camcorder.
Hope this helps!
May 11, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
I have a golden 3 wheel scooter dose charger
If the charger is working correctly, it should turn itself off automatically (may go into float chrarge depending on type of charger). There should be an LED or an amp meter on the charger to tell you when the charge is complete. When the batteries are charged, you should be able to leave the charger switched on and it should cause no harm UNLESS the charger is faulty, in which case it will continue charging and damage the batteries. You should be able to tell if this is happening as the batteries will become very warm. If the batteries are losing their charge after you have switched the charger off, it is most likely that your batteries need replacing. Failing that, you may have a short somewhere which unfortunately, could be difficult to find.
Mar 10, 2010 | Electric Health & Beauty
Our 743 came with a photo docking station that would recharge batteres. Is there another way to charge them
Yes you can., You can need to purchase a wall charger for you r NI-Mh battery the model number of charger is kodak K620 for or if you want a travel charger the model number is kodak K640., Or if your battery is special battery of Ni-MH (KAA2HR) make sure that you will purchased kodak K4500 charger., KAA2HR battery will not charge using a regular wall charger., Check first your battery before purchasing the charger
Nov 16, 2009 | Kodak EasyShare C743 Digital Camera
Nintendo DS Charger
Greetings emitchell,
The Nintendo DS Lite comes with a home wall charger.
Thank you!
Dorothy
Go Ahead. Use Us.
Jul 24, 2008 | Nintendo DS Lite Console
Televison & Video Logo
44 people viewed this question
Top Yes Televison & Video Experts
Marvin
Marvin
NOEL
NOEL
ray gallant
Are you a Yes Televison and Video Expert? Answer questions, earn points and help others
