The gas is flowing through but it doesn't stay alight. Same gas bottle used for gas stove and that works fine. Cleaned burner etc. Still won't stay alight.
SOURCE: ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
SOURCE: Maytag MGR6775 Gas stove. One igniter not working.
Clean the burner with a wire brush around where the ignitor is. it needs a proper ground to ignite. When you turn the burner on do you hear a click click click? If so this should solve the problem.
SOURCE: Gas is not flowing into the burners. The ignition
You have a bad regulator, it is not opening to let gas flow. Call weber they should replace this for free.
SOURCE: Center burner doesn't ignite all the way around
I had this same problem. You will need to lift off the burner and remove the two 9/32" nuts and lock washers from the bottom of the center burner. Then separate the top section from the bottom. You will need to clean the inside of both sections down using a green scotchbrite pad removing and debris or small surface film the may have built up. Then rinse with warm water and dry them well. Reassemble it and your burner should work as good as new. Remember even just a small grease film on the burner holes will create this issue.
