Question about Kenmore Dryers
I have a Kenmore 90 Series dryer model # 110.60902990. It will only run if I hold the start button in and then it will only run for a short period. I have replaced the timer and the circuit board.
Posted by Rick Mills on
5 Related Answers
David Coomer
  • 1073 Answers
SOURCE: Electric Dryer Starts, runs, warms, stops (Kenmore series 90)
you have a bad motor that needs to be replaced
Posted on May 06, 2008
Anonymous
  • 242 Answers
SOURCE: Kenmore Dryer 90 Series will start but suddenly stop...
Hello , Sounds like your motor is over heating , it will run until the sensor shuts it down from getting to hot , it is most likley because the motor is covered in lint and needs cleaned. Hope that helps.
Posted on Dec 30, 2008
Anonymous
  • 85 Answers
SOURCE: Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
Posted on May 27, 2009
Sal De
  • 2699 Answers
SOURCE: Kenmore Dryer-90 Series- Pushed Start button nothing happened
get a meter,unplug the dryer and read out the fuse,pull one of the wires off when you read it out,also when was the last time you cleaned out the dryer?if it's the fuse usually the air isn't moving very well,you need to clean out the duct that the lint filter slides into,vac out the inside of dryer where the motor is and clean out the vent line and make sure the outside vent is clear,if it's a long run from the back of dryer to the outside i use a leaf blower to blow out the vent line,make sure you have 240 coming in at the back of dryer,you could have a blown fuse,if the thermal fuse is good,check the thermostats on the heater box and read out the heater,good luck,if i can help with anything else let me know
Posted on Mar 26, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: kenmore 90 series won't start timer ticks
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 29, 2010
The start button on the kenmore 90 series dryer starts the drum but won't keep running
There is a relay which goes bad mounted in the control panel. Some times it is part of the start switch and some a separate unit next to it. Need model to prioperly advise.
Jun 03, 2014 | Kenmore 63942 Dryer
Kenmore 90 series dryer.. The start button only works if you hold it down and when you let it go it stops running. Is this just the button or a sign of a bigger problem?
It is not the button you either have a broken belt. a bad broken belt switch or a bad motor or something dragging down the drum making it impossible for the motor to get up to run speed
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 01, 2012 | Dryers
Dryer doesn't always start, and doesn't keep running
your have a dieing dryer motor,weak weak to turn the drum anymore,the model number is inside the dryer door if you want to try and find one cheap on ebay-mike
Feb 23, 2010 | Kenmore Dryers
Kenmore 90 series won't start timer ticks
heatman101
Dec 03, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer not getting hot
fist make sure the fuses are good.. unit will run on 110 but not heat.. check connectores and cables or pigtail. it not.. then check heater coils and or thermostat...
Jun 13, 2008 | Kenmore Dryers
Dryers Logo
150 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
