Generator worked great last year. Engine starts and runs just fine, but when turning the breaker on for power, nothing happens. No power. Any suggestions?
SOURCE: generator runs producing no power
Hi, remove the electric control panel & check the wiring as sometimes we have seen the wires coming off the voltage change over switches.
Also some of these units you can check the connections in the rear of the alternator & if it has brushes that they are not stuck.
Another problem we have had is the trip switches have went faulty but still switch operates ok, they need to be checked with a probe type tester for conductivety.
Posted on Nov 29, 2008
SOURCE: Honda EM 2500 Generator
I posted a general tutorial on troubleshooting this problem here.
Rate me?
Carl
Posted on Dec 05, 2008
SOURCE: Generator stopped producing electricity
if the generator has been sitting for a while you might have to excite the magnets to start producing power. plug in a reversible drill and with the generator running turn the drill in the reverse direction by hand while holding the trigger in the forward position.
Posted on Jun 14, 2009
SOURCE: Lombardini diesel generator starts and runs fine but no elecpower
remove the covering panel and expose the internals , check for loose/disscontected push on ( lucar ) connectors , if these are fine it is most likely the excitation capacitor is deffective , replace with exactly the same value/voltage rating/duty cycle . the capacitor is usual 1 or up to 3 cylindrical tubes with 2 wires comming from them , always take a note of exactly what wires you have taken off :) hope this helps
Posted on Oct 20, 2009
SOURCE: generator runs, but produces no power
If it's still under warranty take it back to the retailer and tell them it quit working - don't offer any other information.
If you must fix the E/G yourself - On the generator there's a cover on the back; take the cover off so that the back of the windings are exposed. You should see 4 to 6 diodes mounted to the rotor and stator...those diodes are most likely burned out because of temperature failure, due to overload. You have to take them out to isolate them...they should read .6 Ohms one way; reverse the leads and they slhould read about 1.2 Ohms. If there shorted you'll read 0 Ohms and open infinety.
Anyway, replace those diodes and you should re-establish your field winding voltage which develops you A/C output.
Good Luck,
Mike...
Posted on Nov 24, 2009
Jan 21, 2016 | Electrical Supplies
on Aug 19, 2015 | Electrical Supplies
Jan 13, 2016 | Coleman Electrical Supplies
Dec 24, 2015 | Husky Electrical Supplies
Jun 12, 2014 | Kohler Electrical Supplies
Jun 13, 2012 | Porter Cable BSI550 W 5,500 Watt Generator...
Aug 31, 2011 | Northstar Generator 9 Hp, 5500 Watt,...
Mar 16, 2010 | Pramac Electrical Supplies
Feb 06, 2010 | Briggs & Stratton Power Products 5,550...
Apr 16, 2009 | Hammering
547 people viewed this question
