Sharon Goecke Posted on Apr 09, 2018
Putting a paper shredder back togther - Shredder Office Equipment & Supplies
2 Related Answers
rzachsed3
Wally Zacherle
  • 6 Answers
  • Posted on Nov 13, 2008
SOURCE: torque settings for holden 308
see if this site helps you.
http://www.boxwrench.net/specs_index.htm
Anonymous
  • Posted on Feb 20, 2013
SOURCE: Jammed paper shredder motor stopped won't start
Had this sort of thing happen to me also; sort of. Did you check to see if the shredded paper level alarm has been triggered in the pull-out catch area? Sometimes it forms a pile that trips the alarm before the catch is full. Sounds simple, but check it out. Also check to make sure it's plugged in! I've done that several times, even to the point of calling for help! Did you know the technical help desk always asks if the machine is plugged in first!
I oiled my intimus 280 and it stopped shredding.
It's possible that some residual oil or debris is causing the shredder to malfunction. Try unplugging the shredder and cleaning the blades and feed slot with a clean, dry cloth. Then try running the shredder again with a small amount of paper to see if it functions properly. If it still doesn't work, you may need to disassemble it again and check for any other blockages or damage to the shredder blades. If you're not comfortable doing this yourself, it may be best to seek the help of a professional shredder repair service.
The shredder makes a "horn" like sound before putting paper inside the slot
Many shredders will do a quick reverse to be sure that the path is clear.If the sensors detects NO PAPER it turns off quickly. If there is paper in the shredder, it would continue until the path is clear, or it will time out. I think about 15 seconds or so.
1helpful
Why does my paper shredder make a clicking sound when I try to shred a piece of paper?
Try putting a piece of paper in enough to start it running, but not so far as to go into the shredder. See if it will run for a minute or two. Sounds as though it may be over heating.
1helpful
When trying to use the 160MX crosscut paper shredder, when you insert a piece of paper it starts to go in then stops. If you hit reverse the paper comes back and the edge is cut up. The motor sounds...
Try putting some "shredder" oil onto the cutting blades...they should be lubricated routinely and if they have never been oiled they just may be plugged up with paper dust and debris.
1helpful
Shredder struggles to shred paper. Do I need to oil it? It is an SD5X shredder mad in China. Itasca of Illinois is also on it.
MOST STRIP CUT SHREDDERS DO NOT REQUIRE OILING...IF ITS A CROSS-CUT SHREDDER MOST CERTAINLY YOU SHOULD BE PUTTING OIL IN WHERE THE PAPER IS INSERTED.
I was shredding paper - less than 8 sheets - and I didn't realize the receptacle was full. The shredder jammed and reversing it does not help. How can I de-jam?
When you unplug the shredder and take the top off, pull any jammed sheet through. Empty the receptacle. Then try putting the top back on and plug in and test it.
Paper won't go through
already death for your shredder. Please go buy a new one.
Shredder does not pull in paper to be shredded.
you might be putting to much paper into the shedder
try putting 3or 4 sheets at a time and put a little oil on the blades
1helpful
2answers
Infoguard shredder jam
When you set it to reverse, it Should propel the paper back out the top, where it's jammed. If it does not, remove power to the unit, and get ready for the long laborious process of removing the jam with a pair of tweezers. A hazard of paper shredders, maintenance can be a bit on the silly side.
Top Shredder Office Equipment & Supplies Experts
NOEL
NOEL
john h
Are you a Shredder Office Equipment and Supply Expert? Answer questions, earn points and help others
