Question about Hayward Pool & Spa
SOURCE: what is the normal psi on a haward sand filter
i was told that between 9 to 12 psi is normal on all pool pumps.
Posted on Jun 29, 2009
SOURCE: hayward 1hp super pump stops working
Your motor has a thermal protection switch in it the reacts to an overheating condition. Once the motor cools enough it will turn back on. You may be able to have the motor rebuilt for about half the cost of new if it is not damaged to severely. Take it to a local electric motor repair shop for service. If it is damaged beyond repair, you can shop around for a new one. If you would like a quote, contact us at www.arrowpools.net with your pump model number and we can quote it.
Posted on Jul 12, 2009
SOURCE: my hayward 1hp pool pump is running very hot to
Make sure the supply wire is the correct gauge for the current draw. The main reason to run on 240 volts is a smaller gauge wire and breaker than on 110 which draws close to 15 amps. For example a person using an above ground on a small extension will cause it to overheat. Make sure it is getting as much power as possible
Posted on Jul 20, 2009
SOURCE: my hayward northstar pump makes a loud noise when
If you have a crack in your basket you may have a clogged impeller. With the power off reach back into the pump through the pump pot with a long screwdriver and feel around. If it feels spongey it there you have a clog. Take the serew driver an use an oceleting motion in a counter clockwise direction this should loosen the clog then reach in with a long set of thin pliers and pull the clog out. This should fix your problem and once water is flowing your pump should quiet down.
Posted on Oct 03, 2009
SOURCE: hooking up filter to pump and pool
This website contains a copy of the owners manual for the S180T pool filter. It should have all of the information that you need.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
It is in PDF format. let me know if you have any trouble opening it.
Posted on May 24, 2010
Jun 21, 2014 | Hayward H Series Pool & Spa Heater 400k...
Apr 14, 2013 | Intermatic 220v T104p Swimming Pool Pump...
May 24, 2011 | Hayward 1hp Power Flo Matrix Above Ground...
May 31, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
Mar 18, 2010 | Plumbing
Jan 18, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
Jul 03, 2009 | Hayward Power Flo Lx 1 Hp Pool Pump Sp1580
53 people viewed this question
