Question about Locks & Locksmithing
I want to reset the number to another in my TSA 002 lock
Posted by Raman K on
2 Related Answers
Nrjunior18
SOURCE: delsey TSA
I bought a TSA.There is no any key.What should I do?I left the country,where I bought.
Posted on Aug 31, 2011
timlippard
timlippard
  • 15 Answers
SOURCE: How do you unlock a TSA COMBINATION LOCK WITH fogotten. number?
The only way to reset a TSA Combination lock is to turn the numbers until you get it. The good news is that you only have 1000 possible combinations. Start at 0 0 0, then 0 0 1, 0 0 2, etc...
There are posted videos on YouTube that talk about how to reset locks with unknown combinations but they are specific to the brand of the lock; assuming they aren't fake videos anyhow.
Posted on Nov 19, 2013
Nov 19, 2013 | Home Security
Eminent luggage lock
TSA lock on Eminent Osmosis Luggage, three digit TSA lock (HOW to change it to YOUR personal number)
Put the code numbers to '000'
Take the lock levers OFF the lock
Push the round opening button UPWARDS.
IMPORTANT :
KEEP holding the button UP until you have changed the numbers
Change the TSA code numbers to what YOU want
Release the round opening button
Now your case combo lock numbers have been changed.
To lock the case put the two lock levers into the holes, spin the numbers and your case will be locked.
To UNLOCK the TSA code spin the numbers to YOUR lock code, push the lock button UP and, hey presto, your case will open.
If you forget your NEW lock number you will NEED to go through ALL the numbers, starting at '000' to '999', to be able to open the lock/case.
REMEMBER to PUSH the ROUND OPENING button UPWARDS on EVERY number change.
Only THEN, when it finds YOUR correct three digit number, will it eventually open the suitcase/luggage/baggage.
Good luck
Aug 31, 2013 | Luggage & Travel
Delsey TSA 002 HOW DOES IT WORK
May 10, 2011 | Locks & Locksmithing
TSA locked our TSA002 lock on our samsonite bag when they inspected it. We do not have a key. TSA said we needed to go back to the airport, but is there a way to get a key?
No. That's part of the whole purpose of TSA passkeys; they're held securely and only at ports. If it were easy for anyone else to get hold of them the locks which are TSA approved would become pointless.
You only have three options if you do not want to return to the airport:-
1. Get a locksmith;
2. Cut the lock off/drill it out;
3. If your lock is usually key operated (not a combination) then there will be a number next to the lock barrel (not the TSA number, that just tells the TSA which of their passkeys to use). A Samsonite dealer can order the correct key for you using the number and some even keep them in stock.
Oct 23, 2009 | Samsonite Tripod
Locks & Locksmithing Logo
897 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
