Question about Smith Corona Office Equipment & Supplies
Install correction tape on smith corona PWP365DS.
Posted by William Due on
Mitch Vass
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 147 Answers
The correction tape is two spools it installs on the left side below the ribbon and the right side below the ribbon.
Posted on Jan 20, 2019
5 Related Answers
Dick O Reilly
  • 3594 Answers
SOURCE: Correction tape for my Smith Corona PWP 4500 plus...
Is it making all the motions of a correction? If so you may have put the tape on wrong. The dull side must be towards the platen.
DickyO
Posted on May 19, 2008
Jason Largo
  • 36 Answers
SOURCE: I inherited a Smith Corona WP 48D and need an owner's manual
Please go to www.willrepairservice.com for ALL Smith-Corona repairs, supplies and manuals.
Posted on Dec 18, 2008
Anonymous
SOURCE: Smith Corona 3L (old one)
I agree with JUSTOLDJIM. I recently found a 3L near the dumpster at my townhome. I took it in a looked at it. There is a black and white ribbon used for typing and erasure of ink.
As far as the TAB goes, I haven't used them yet.
Posted on Jan 06, 2009
Anonymous
SOURCE: how to install correction tape and what one to buy?
Where can I locate instruction on how to install the correction ribbon on a Smith Corona electric typewriter?
Posted on Jul 06, 2009
Anonymous
  • 20 Answers
SOURCE: Lift off tape installation
See previous answer just written on the 4500 series.
Posted on Oct 23, 2009
How do I fit the correction tape o a Smith Corona XL1500 typewriter
First, backspace to the mistaken character. You slip the correction tape in the middle of the platen where the type hits, then type the same character, pull out the correction tape, backspace and type the correct character.
Nov 28, 2014 | Smith Corona Office Equipment & Supplies
How do I install the 22210 Correction tape on Wordsmith 250 Smith Corona typewriter
lift the top remove the black ribbon then you can see the lift off tape it should lift up then install the new cartridge.
Oct 16, 2014 | Smith Corona Office Equipment & Supplies
How to correctly install the correction tape in a smith corona electric typewriter SD770
you have to turn the spool with the knob untill there is tension on the tape or it won't stay in place
Nov 08, 2011 | Smith Corona Wordsmith 100 Typewriter
Instructions Smith Corona SD700 Typewriter
IN NEED OF RIBBON AND CORRECTION TAPE FOR THIS MACHINE - SMITH CORONA 700 COULD YOU ADVISE PLEASE?
Oct 02, 2010 | Smith Corona SMC10230 Typewriter
Smith corona 4500 pwp pluse install correction tape
There were two types of correction tape used on these machines. I believe your's uses the two spools. Before you do anything, look at the old ones on your machine and follow along with how it was installed. The full one will go on the left, and the empty on the right. It will feed through a couple of metal prongs I believe. There then is usually a red lever under the spool on the left. click it several times and it will tighten it. (especially true of the cartridge type).
Oct 08, 2009 | Smith Corona Wordsmith 100 Typewriter
Sep 08, 2009 | Smith Corona Wordsmith 100 Typewriter
How to install correction tape and what one to buy?
Jun 04, 2009 | Smith Corona Wordsmith 100 Typewriter
Just started using a Smith Corona SL 480 in church library. Bought new ribbons and correction tapes. Ribbon cartridge went on just fine but I can't figure out how to install the correction tape. It...
I found a manual for a different model Smith corona which may help. Is sounds like the correction cartridge needs to go in first. Here is the link to the manual and best of luck to you.
http://www.smithcorona.com/pdf/Office2000/Office2000Chap7.pdf
May 09, 2009 | Office Equipment & Supplies
DickyO
May 15, 2008 | Smith Corona Wordsmith 100 Typewriter
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Ekse
James Keysor
Level 1 Expert
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
