Question about Necchi Sewing Machines
I cannot load bobbin into my Necchi Sofia 300. ??
Posted by Hilarie Mary Day on
R.A. Ellis
  • Necchi Master
  • 12,731 Answers
Perhaps this will help:
How to Thread Necchi Sewing Machine
Posted on Apr 08, 2018
5 Related Answers
Anonymous
SOURCE: bobbin case on my 524fb necchi has come apart
Almost all Necchi use a class 15 bobbin & bobbin case, a new case should cost around 7 to 10 dollars!
Dwayne
Posted on Mar 14, 2009
Anonymous
  • 47 Answers
SOURCE: necchi sewing machine
www.ifixmachines.com has lots of parts fitted to your sewing machine for a cheaper price
Posted on Jul 23, 2009
miket756
Michael Thorpe
  • 2702 Answers
SOURCE: NECCHI, model 4795. Thread bunches up at bobbin.
it sounds like the thred tenshion is to loos or the timing has sliped a little and its off a bit this can also happen with wear on the gears or just a loos fixing letting the timing slip back a bit,
Posted on Nov 20, 2009
SOURCE: Necchi 215A Sewing machine Could anyone help I
Make sure the bobbin has a 3-5 inch thread tail
Then make sure the top thread has a 3-5 inch tail
Then hold the top thread tail with your fingers (away from the needle)
& use the hand wheel on the right hand side of the machine to slowly
Lower the needle in the bobbin area & see if the bobbin thread will pick
Up that way
Posted on Sep 27, 2010
Testimonial: "Thanks for the answer it did not work for me though"
relicssmm
  • 20 Answers
SOURCE: How do you load the bobbin on a Necchi sewing
What model Necchi SM do you have. Linda at Relics
Posted on Jun 18, 2011
Necci 752 manual is needed.problem with threading and stitching
Hm, I'm not able to locate a manual but may be able to offer some suggestions.
Remove the top thread from the machine.
AVOID OLD OR BARGAIN BIN THREAD!
Use the same thread in top and bobbin.
Be sure to use a brand new needle--needs to be compatible with the thread and fabric of the project..
ALWAYS RAISE the presser foot and rethread from the beginning.
Set the top tension to the midway point.
Verify the bobbin is loaded and threaded correctly and it turns the correct direction.
Pull the bobbin thread up through the fabric before taking the first stitch. It also helps to hold both thread tails in your left hand when taking the first stitches.
Test your machine and tweak the top tension until the top and bobbin threads meet in the middle of the fabric. (Increased top tension will pull the bobbin thread up. Decreased top tension will allow the bobbin thread to pull the top thread down.)
How to Thread Necchi 535FA 535 534FB 534 Sewing Machine and Bobbin Case (not your model, but the threading and basic instructions will be similar or the same as your machine)
How to thread Necchi model 535 FA sewing machine now with captions
Mar 18, 2018 | Sewing Machines
I need a manual for Necchi Sofia 300 sewing machine please
Search for:
Make Model manual
you may be lucky to find one online.
Feb 13, 2018 | Necchi Sewing Machines
My Necchi Sofia 300. When winding bobbin the needle doesn't disengage and the matching makes a dreadful grinding noise as it winds the bobbin
Try putting a small drop of oil on the the metal shaft of the bobbin winder if it is not moving freely. The grinding noise implicates the winder tire may be ground from the locked winder shaft. The needle not disengaging requires oil in the shaft bushing. On this machine it appears you would have to remove the covers to access the appropriate areas.
Dec 05, 2016 | Necchi Sewing Machines
Necchi 215A Sewing machine Could anyone help I have a Necchi 215A which will not catch teh bobbin thread, I have tried a new needle and checked the bobbin is loaded and fitted correctly. The needle passes...
Up that way
Sep 26, 2010 | Necchi Sewing Machines
Threading the bobbin- Necchi 535FA
Hi - I have a 510 Necchi sewing machine - how do a fill the bobbin?
May 04, 2010 | Necchi Sewing Machines
How do i thread the bobbin on my necchi 539
take out your bobbin and turn it the other way
Feb 02, 2009 | Necchi Sewing Machines
Bobbin case on my 524fb necchi has come apart
Dwayne
Dec 02, 2008 | Necchi 3537 Mechanical Sewing Machine
Sewing Machines Logo
105 people viewed this question
Top Necchi Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
