Question about Locks & Locksmithing
I am using my Defiant electronic deadbolt lock /there is no model number/. So I did how instructions telling me how to delete old code but there is no progress. Any suggestion?
Posted by Mirko Plahcinski on
5 Related Answers
Anonymous
SOURCE: how to change the battery on my BE365-CAM-716 Schlage Keypad Deadbolt
Problem fixed by having my wife look it up on the Schlage website. The deadbolt has a flash memory so your combinations and codes will not be lost when the batteries are changed.
Posted on Sep 30, 2008
Phil Oellrich
  • 158 Answers
SOURCE: carbine 4011 deadbolt removal
First, you will need a good quality Phillips Type Screwdriver, and possibly a flat-blade screwdriver, also. Both should be Medium-to-large to fit the lock screws properly. A Cordless Electric Screwdriver is OK, also. With the door open, remove the two screws holding the bolt assembly to the narrow part of the door. Do not attempt to remove the bolt at this time. Next, on the INSIDE part of the door, look on the lock cylinder for two screws. Before removing the screws, use masking tape to hold both sides of the lock to the door. The tape will keep the cylinders from falling off the door during disassembly. Now, remove the screws from the cylinder, and carefully pull the inside and outside cylinders off of the door. Sometimes there are two additional screws inside the lock that must be removed. Wiggle or rotate the cylinders slightly, and they should come right off the door. With the cylinders removed, the bolt assembly can now be slid out from the side of the door. Put all the lock parts, including keys, in a container so nothing gets lost.
Posted on Oct 04, 2008
Coaltowner
  • 963 Answers
SOURCE: Kwikset smartcode deadbolt. The
Let's review the programming steps, in case you are overlooking something. This information was found at this link:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
Important before proceeding: 1. Verify that position #2 of the "Settings
Switch" is in the OFF position. (Refer to section 11.) 2. Work with the
door open (away from jamb) to avoid accidental lock out. 3. Make sure
the bolt of latch is in the extended (locked) position
8. Automatic - Bolt Direction Determination (Door Handing).
IMPORTANT: DO NOT SKIP THE FOLLOWING STEP.
LOCK WILL NOT BE ABLE TO OPERATE PROPERLY!
? In the steps below, the SmartCode mechanism automatically determines the "door handing" and sets the proper direction for motor to rotate.
a. Press and hold the "LOCK" button on the exterior keypad, while fully inserting the battery pack into the interior assembly (the tabs on the pack must face out)
b. When the unit begins to operate the bolt, release the "LOCK" button.
c. Do not disturb the unit for approximately 20 seconds until the interior Green LED flashes followed by a beep. During this time the system will drive the bolt several times, will determine "door handing", store data in memory and exit. It is very important that this process is allowed to finish properly.
Proceed with programming your Usercodes per the instructions.
Finally, here is the contact number for Customer Service At Kwikset. Call them if you still have the problem.
1-800-677-5625
Posted on Aug 04, 2011
Gord Stringer
SOURCE: I bought Rona Collections Electronic Deadbolt. My
You must ensure the deadbolt is in the locked position when attaching the control mechanism. The control mechanism must also be set to the locked position. Turn the manual knob to the left then attach the mechanism (with the batteries) to the flat pin. You can do all of this with the door open, so you can enter the codes. My initial install created the same issue. It worked properly out of the package, so that meant that I screwed something up. You don't need to return the item. Just do a little fault finding.
Posted on Dec 28, 2011
Coaltowner
  • 963 Answers
SOURCE: What does 4th Future Feature button do on Kwikset Electronic Deadbolt lock?
Nothing.
Posted on May 26, 2012
Defiant electronic deadbolt manual
I only saw manual mentioned on suspicious or malicious websites/
Sometimes manuals appear for sale on eBay.com or Amazon.com.
Home Depot could be contacted for a manual, as it is their brand name.
Searching for a youtube video might help you.
Example:
https://www.clipzui.com/video/u3q464q2u3z4p4m4162524.html
Electronic Deadbolt Door Lock Install Defiant clipzui com
Apr 21, 2018 | Locks & Locksmithing
I have a Defiant Electronic deadbolt from home Depot. model G1X2D01. ive lost the manual and i need to delete some old codes from it.
Snap off the back cover (opposite where you punch the numbers) by pinching the sides and pulling off. Do not press a pen or anything into the small light, you do not need too. Just pinch and yank off cover. You will see a small light and beside it is a small SET button by the batteries, it is labelled.. Press this Set button for 2 seconds. The red LED will light on the front code side and beep twice to indicate you are in programming mode. Enter your current code that you want to change (factory set is 12345) and then press the button that looks like a little lock on the keypad. Enter the digits "10" and press the lock button again. Enter the new code (must be six digits) and then press the lock button again. The red light should go on continously for 10 seconds. The code should be effective.
Note: if you have problems like we did, you can also remove one battery and press the "set" button simulataneously when you reinsert the battery. This resets the factory code of 12345. Then you can start over. For some reason our old code was only 4 digits, but it would not let us reprogram a 4 digit code. It didn't work until we did a 6 digit new code.
Apr 15, 2012 | Locks & Locksmithing
Lock will not unlock with code
You do not indicate whether this is a new installation or an older lock that quit working.
In any case, here is a link to the installation instructions for the 907-15:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
Please read and review these instructions. If the battery is old, this is a good time to replace it.
Programming and troubleshooting instructions are included, as well as a number that you can call to contact Kwikset directly for parts and assistance.
May 24, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
I have followed the instructions on how to change my entrance code, but am not being successful. I even changed the nine volt thinking that might be the problem. It blinks red quite a bit. Do I have to...
Here is a very useful link to a video on reprogramming the BE365 lock:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Apr 26, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
How do I set the key pad to my on code on my schlage electronic keyless lock
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks, including the BE 365:
Jan 13, 2011 | Schlage Lock BE365VCAM716 Electronic...
I would like to program the schlage deadbolt keypad using my personal code.
This link will give you instructions for various models of Schlage locks:
There is a video on that page.
Dec 18, 2010 | Schlage Camelot Deadbolt Keypad, Satin...
Manual for changeing code
Nov 12, 2010 | Schlage Camelot Deadbolt Keypad, Satin...
Locks & Locksmithing Logo
411 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
