Question about Blomberg Refrigerators
The manual may have the information https://www.blombergappliances.com/user-manuals
Posted on Feb 25, 2019
SOURCE: maytag mfd2561 water dispencer and ice maker issues
Most likely it is the High Voltage Control board located in the unit compartment (take off the back cover where the water lines are) i have had lots of them failing and doing all kinds of odd things, so far it has been that computer. Part number 12002608
Posted on Sep 29, 2007
SOURCE: Kenmore Fridge- all lights blinking
sorry to say this but the mother board has took a hit replace this and all will be well
Posted on Jan 01, 2008
SOURCE: GE French Door handle loose
To tighten the screw the first step is to remove the handle. With this model just pull straight up on the handle. It can take a little force but after it finally unclips it moves up an inch or two then pulls straight out. Good luck!
Posted on Nov 07, 2008
SOURCE: Changing Door Mirror Glass XJ6(X300)
Hi
You need to put on a pair of gloves, and safety glasses. (Safety First !)
Prise off the broken mirror from the plastic base that it is stuck too.
Give the plastic a clean with nail polish remover or similar.
Peel off the backing on new mirror glass, and carefully stick it on.
Good Luck !
Don´t forget to FixYa Rate Me Please !
John.
Posted on Feb 06, 2009
SOURCE: Replace drill chuck on 23 year old Craftsman 8" drill press
Yes it does have a Morse taper and you can remove it by gently hitting it with a rubber or nylon mallet.
Posted on Feb 08, 2009
Sep 28, 2010 | Maytag (MFI2568AEW) Bottom Freezer French...
Apr 05, 2010 | Samsung RF265AA Bottom Freezer French Door...
Feb 14, 2010 | KitchenAid KFCS22EVMS Stainless Steel ...
Dec 23, 2009 | Samsung RF265AA Bottom Freezer French Door...
Oct 20, 2009 | LG 24.7 cu ft Panorama French Door...
Aug 30, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Jul 12, 2009 | Maytag MFD2560HES Bottom Freezer French...
Aug 16, 2008 | LG LRBC22544 Bottom Freezer Refrigerator
148 people viewed this question
