Question about Amerock Hardware & Accessories
Deadbolt striker is a little too long. Can it be adjusted?
Posted by Pam Eliason on
Frank Racibo
Have you tried calling AmerlockForLess.com for assistance? On their website they say: "American customer service reps by phone from 8:30 to 5:00 M-F. Our toll free number is 1-877-261-5805."
Posted on Apr 07, 2018
The chimes on my hermle movement 150-070 sound funny. It's a bell and "clunk" sound as the strikers hit the two bells. Is there an adjustment?
You need to bend the arm on the one hammer back that is making the clunk sound. You will have to experiment a little until you get the sound you are happy with.
http://usedclockparts.com/8-clock-movement-repairs/19-how-to-change-the-sound-of-a-clock-gong
Oct 07, 2016 | Home
Why won't my schlage deadbolt key go to the neutral spot in the lock position to remove the key?
You likely have the lever that goes from the outside portion of the lock through the striker/bolt assembly into the inside portion rotated into an incorrect position when you insert it into the striker/bolt assembly.
Sep 18, 2014 | Locks & Locksmithing
Trunk won't close
If after every re-adjustment the trunk close only to refuse to close after sometime, it is posible that striker is not tight enough and probably shifting after some uses. It is likely also that the threads on the bolts or screws are worn lightly. If posible try using a spring washer or some threadlocker medium strenght.
Jan 31, 2014 | 1995 Nissan Altima
I purchased a schlage lock and the deadbolt won't
Check for clearance between the deadbolt and the striker plate in the jamb
Jan 19, 2013 | Locks & Locksmithing
Doors where hard to close without the weather door seals. But with them on they will not close. The body plates more but not enuff on the cab? I need HELP.
Hi!!
The doors Hinges or Striker need to be adjusted to make up for the weatherstrip thickness. To do this, loosen the hinge-to-door bolts for lateral adjustment only. Loosen the hinge-to-body bolts for both lateral and vertical adjustment.
REAR DOORS
BEFORE YOU START:
  • Determine which hinge bolts are to be loosened and back them out just enough to allow movement.
  • To move the door safely, use a padded pry bar. When the door is in the proper position, tighten the bolts to 19-25 ft. lbs. (26-35 Nm) and check the door operation. There should be no binding or interference when the door is closed and opened.
  • Door closing adjustment can also be affected by the position of the lock striker plate. Loosen the striker plate bolts and move the striker plate just enough to permit proper closing and locking of the door.
TO ADJUST ON A: F-150, F-250, Expedition and Navigator
HORIZONTAL AND VERTICAL ADJUSTMENT
  • Loosen the front door hinge to front door bolts.
  • Adjust the front door alignment.
  • Tighten the front door hinge to front door bolts to 19-25 ft. lbs. (26-35 Nm).
FRONT DOOR FORE AND AFT ADJUSTMENT Check the rear door hinge adjustment before adjusting the front door hinge.
  • Remove the front fender.
  • Loosen the front door hinge to body bolts.
  • Adjust the front door alignment to specification.
  • Tighten the front door hinge to body bolts.
  • Install the front fender.
1999-00 F-Super Duty Models
DOOR ADJUSTMENT The following procedure is for performing fore, aft, up, down and tilt adjustments.
  • Remove the door striker.
  • Loosen the bolts only enough to allow for slight door movement.
  • Carefully close and adjust the door until flush with the adjacent body panels.
  • Carefully open the door and tighten the bolts.
  • Re-install and adjust the door striker.
  • Check the door for proper operation and alignment.
STRIKER ADJUSTMENT Mark the position of the striker before loosening.
  • Loosen the striker retaining bolts.
  • Adjust the door striker and tighten the striker retaining bolts.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 09, 2010 | Ford F Cars & Trucks
I need a fuse box diagram for a Mercedes A140
Sounds like a faulty door switch check the door switch and also the door striker adjustment,Is the door sticking out a little? if so just loosen the screws and adjust the striker inwards.
Mar 03, 2010 | 2006 Mercedes-Benz B-Class
The drivers door will not close fully even if you push it real hard it really never will click into that lock position
open the door loosen the striker on the door jam and adjust it by slidding it back and forth, also if the door has drooped a little loosen the lower hinge and put a 3/8 shim between the hinge and door!!!
Nov 24, 2009 | 1990 Chevrolet K1500
I have deadbolt segal lock that was working for 2 months. suddenly today i can't lock the door from the inside. locking works from the outside. when i lock it from the outside i can unlock it from the...
Sounds like the tumbling mechanism for the handle may be off......check to make sure that the screws are tight that lock the front and back of the deadbolt together. Make sure that the door is fully closed and check to see where the deadbolt is hitting the striker. It mat be as simple as the door and frame have expanded a bit and the door is not fully seated when you close the door from the inside. See if these help if not please contact me as I wish to find a solution to your problem.
Thx
Deathstalker
Aug 21, 2009 | Locks & Locksmithing
What is the means of opening the fuel tank door on a 2009 Subaru Forester?
i'm guessing you have a problem with the release cable?try slipping your credit card in between door and plunger that pops it open,the plunger is located at the rearmost centerof the door ,the door striker that rsts against plunger could just be out of adjustment,if you operate the release and see the plunger moving it's ok,adjust the striker a simple little tug towards the plunger is sometimes all it takes
Jul 30, 2009 | 2003 Subaru Forester
Power slide door dosent close all the way
CHECK THE PIVOT HINGE AT THE REAR OF THE DOOR, IF BAD IT WILL THROW THE DOOR OUT OF ALIGNMENT.
THE STRIKER AT THE FRONT OF THE DOOR CAN CAUSE IT NOT TO CLOSE ALSO. SLOWLY CLOSE THE DOOR AND LOOK AT THE STRIKER TO LATCH POSITION. IT SHOULD BE AT THE CENTER OF THE LATCH. IF NOT ADJUST IT TO FIT BETTER.
CLEAN THE CONTACTS WITH SCOTCH-BRITE THEN PUT A LITTLE DI-ELECTRIC GREASE ON THEM.
Jul 15, 2009 | 2004 Chevrolet Venture Passanger
Hardware & Accessories Logo
67 people viewed this question
Top Amerock Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you an Amerock Hardware and Accessory Expert? Answer questions, earn points and help others
