SOURCE: THE MODEL # IS WFW8300S WHIRLPOOL DUET SPORTS WASHING MACHINE
a power glitch can cause this promblem first push pause cancel twice to clear this error code then try the washer on drain spin and listen for the pump to come on if it does then clear the machine by pause cancle twice then try to start again if code resets then the promblem is most likely the ccu or the board but try clearing the error first if that dont work get back with me and we will run diagnostic mode
SOURCE: flashing code F-6
F06
Drive motor tachometer error
The control is unable to properly detect motor speed and the machine will
shut down. If a failure occurs during high-speed spin the door will be
unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and
the Motor ControlUnit (MCU), and between the MCU and the Central Control
Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
SOURCE: f14 code on whirlpool duet
the central control unit{ccu}receives its data from an eeprom onboard the ccu.a power glitch may couse this error.unplug washer for two minutes.verify ccu operation by running a diagnostic test or any cycle.if you still have a problem you nead ta replace tnhe ccu.
SOURCE: My whirlpool duet sport washing machine has F-28 error
i have the same problem... and i got it fixed 3 times.. the frist time.. there was stuff stuck in the pump... but every time i go look in the pump.. theres nuthing and i still get f-23... good luck..
How to fix a Whirlpool Duet & Duet sport error code F02. Repairing your F02 error code can usually be done without ordering parts. Tools needed to repair your Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out. With the filter out, clean and install back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back it may require you to clean the drain pump filter again.
