Question about Jet Health & Beauty
Jet 3 chair will just stop no lights flash will start short time later
Posted by bob kinderknecht on
5 Related Answers
Anonymous
SOURCE: Whirlpool ADP951 Dishwasher
Processor board sound bad. May be a loose plug ( or corroded connection on the plug ) . Unplug the dish washer from the wall plug before servicing. The open the front panel to expose the panel control board. Unplug the panel plugs and inspect them to assure no corrotion is apparent. If you see corrotion, use a pencil erracer to clean all contact points on the board and clean the plug the best possible. Plug the dishwasher plug back in the wall and check the unit for proper operation. If the operation is not correct, replace the circuit board. I hope this helps
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 06, 2008
Anonymous
SOURCE: The charge lights blink and the chair won,t go.
Just had this problem with my Guardian Aspire. They had to replace the electronic box with the joy stick. BIG BUCKS!
Posted on Mar 13, 2009
Anonymous
  • 40 Answers
SOURCE: lights just flash on controller and wont move jet 3 wheel chair
Do they flash in series? Like ten flashes then a pause then ten flashes?
Posted on Mar 30, 2009
Anonymous
SOURCE: lights on hand control flash off and on and chair will not operat
There is a series of diagnostic flash codes associated with the controller. The diagnosis depends on which color and how many lights are flashing. If you post the combination, I can help you. Or you can download the Basic Operation Instructions of the Pilot Controller from the Pride website. The codes are listed on page two on the troubleshooting instructions.
Posted on Apr 14, 2009
Anonymous
  • 29 Answers
SOURCE: pride mobility Jet 3 Ultra Power Chair 7 flashing
a 7 Flashe code. There is a joystick fault. Make sure the joystick is in the center position and then power off and on again. Check all your couplings. make sure when turning on the unit you only mash the power button for 1 sec. 2-3 sec will put the unit in "Lock out mode".
This ierror will also be present if the joystick is off center when powered up. If you experience these symptoms, you must first make sure there is no physical damage to the joystick preventing it from returning to the center position. Then turn the power off and back on again (making sure the joystick is not depressed in any direction. If the joystick repeats this error, the controler much be replaced. [email protected]
Posted on Sep 07, 2009
Chair won't move..lights flash continuously
You may have locked it by holding the power button . try turning it on then hit thee horn 2 times . That should unlock it.
Jul 16, 2014 | Jet 3 Ultra Power Chair
When I turn on controller power the speed lights flash slowly. Joystick does nothing and chair is dead. Chair is Pride Jet 3 Ultra.
Do all of the speed lights flash at the same time or do they ripple from left to right? If they ripple from left to right the chair is in lock mode and you can use the unlock procedures from my tips to unlock. If they are all flashing at the same time you have an internal joystick problem and the joystick needs to be replaced Hope this helps
Apr 27, 2011 | Pride Mobility Products New Pride Mobility...
WHEN I TURN THE POWER ON FOR MY JT3 ULTRA POWER CHAIR, THE LIGHTS THAT INDICATE THE STATUS OF BATTERY BLINK ON AND OFF (REGARDLESS OF BEING FULLY CHARGED OR NOT) AND THE CHAIR WILL NOT MOVE. SOMETIMES,...
I would replace the batteries with new ones anyway to make sure that you are getting full power and if the problem stops great if it continues then you have eliminated one possible problem. A low battery will cause the problem and these chairs diagnose themselves with the controller giving you flash codes to indicate a problem. I would just check for a loose connection in the wiring when you have the seat off changing the batteries and give the base a good cleaning( without water) (Use those cleaning wipes from dollar store) Hope this helps you
Sep 08, 2010 | Jet 3 Ultra Power Chair
When switched on power light flashes.
How many flashes? Count number of flashes should be a slight pause then flashes the same number of times . Your manual will give you flash codes and you can determine what the problem is. If all the lights are flashing and there is no pause the chair could be in "lockout" Your manual should tell you how to get the chair out of lockout I think that Pride uses the joystick to get it out of this mode.. Turn the chair on move the joystick forward till you hear a beep then move the joystick to the rear until you hear another beep release the joystick and the lights should quit flashing Hope this helps
Aug 12, 2010 | Pride Mobility Products New Pride Mobility...
Hello, The green battery lights seem to go out rather quickly, and then the speed LED's flash on/off and the chair slows way down. After recharging it fully last night, the speed lights started flashing...
It sounds like a battery problem more than anything. If it were a fuse, the chair would not move at all. When batteries are stored, they need to be kept charged by charging every couple of week or so (ideally). There may be other problems causing this, such as a short somewhere or a problem with one of the motors/brakes/electronic componets draining the batteries, but I feel this is unlikely given what you have described. I would have the batteries checked at a dealer with a proper battery tester. Preferably have the charger checked at the same time. We use a specific battery/charger tester in our shop that is connected to a computer and will give a graph of the battery/charger condition. This way there is no arguments as to whether the batteries or charger is faulty. Hope this has helped.
Mar 24, 2010 | Jet 3 Ultra Power Chair
Jet 3 power chair power lights just flash, no sequence of flashes
hold joystick back, press on button, move joystick forward, then let go.
Feb 17, 2010 | Jet 3 Ultra Power Chair
Lights just flash on controller and wont move jet 3 wheel chair
Mar 27, 2009 | Pride Mobility Products New Pride Mobility...
Health & Beauty Logo
75 people viewed this question
Top Jet Health & Beauty Experts
Marvin
Marvin
Vincent G
Vincent G
ray gallant
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
