This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch
or mount trouble can be caused by slamming the door or by opening the
door while it's cooking without hitting the Stop pad first.
There are
plastic mounts inside the microwave which hold the door switches and
onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's
a broken tab on the switch holder, allowing the switch to rotate just
out of position. This tab can be hard to see, since it is under the
bottom edge of the switch.
One test that sometimes helps is to
gently lift up (and/or push down) on the door or handle as you try to
start it. If it works or tries to work, then it's a door switch mount or
door alignment issue.
If you or someone you know decide to look
into it, we have critical information on safety, disassembly and door
switches at our site, and our link is at
our listing here on FixYa:.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
For more help from Emerson
visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
