Question about GE Dishwashers
GE Quiet Power 3 won't start when door is closed.
My Ge Quiet Power 3 Dish washer has been acting strange lately. One day after I loaded it and closed the door, the control panel started blinking, beeping, and clicking rapidly until it shut off. The door latch was in pretty rough shape so I replaced that, but it didn't solve the problem. The door shuts tightly, but the control panel does the same thing when I close the door. Once it shuts off, I have to turn the breaker off for several hours and keep the door open to get any signs of life. When the door is open, the Light and Heat Dry lights are on and blinking like I opened the door during a running load, when I close the door to cancel the cycle or reset it, the same thing happens where the control panel rapidly blinks, beeps and clicks, then shuts off until I turn the breaker off for hours. Any ideas? I'm hoping I don't have to replace the control panel. I got this Dishwasher on clearance and a new panel is more than what the washer is worth.
Posted by nasfat on
  • GE Master
  • 18,438 Answers
What is the exact model number? This may be an issue with the cables that connect the door to the power supply.
Posted on Apr 07, 2018
  • nasfat
    nasfat Apr 07, 2018
    The model number is GCD4800L00S.
1 Related Answer
joe_lishman
Joe Lishman
  • 192 Answers
SOURCE: GE Dishwasher no water upon start, humming, blinking lights
Seems like the anti flood is activated when water (even a small amount) appears on the bottom of the machiene. This is usualy a leaking pipe but can also be caused by a clogged pipe. Most machiens do have a plastic pipe that (from the flat water tank) feeds water to the bottom of the machiene in case of an internal fault. The anti flood is normaly a polystireen float with micro switch on the base of the washer. This automatically puts the outlet pump on to drain the water. The machiene does not work exept the outlet pump in this mode.
Posted on Jan 18, 2010
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
Ge dish washer just installed. First run. All lights working but cycle will not start. Error beeps indicate door not closed but it is.
That is exactly what the problem is. There is a switch on the door latch, it is not showing the door is latched. Could be bad switch, loose hardware or not connected,
Jul 08, 2017 | GE GDF570SGFBB Fully Console Dishwasher...
Kenmore HE2 Won't Turn On
1) test the power cord for open 2) test the outlet box, see for blown fuse or c.breaker put some desk lamp and see if work 3) test inside of the control board if there fuse blown or c.breaker tripped 4( test the lid switch is closed, can be faulty or open replace 5) test the input voltage 115 if there are the control board faulty.
Jul 18, 2012 | Kenmore HE2 Plus Front Load Washer
WCVH6260HWW GE front load washer won't start - press the On button, then press Start/Pasue button and it goes beep beep, and keeps blinking, and washer does not start; the washer pump strainer has been...
no power to control panel checked outlet with another appliance it worked drained water from pump filter still nothing door locked and nothing on control panel
Feb 23, 2009 | GE WSXH208A Front Load Washer
GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Mar 12, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE Frontload Washer Adora series duet pair
you may or may not hear clicking as it tries to start.
See this link for troubleshooting it. and to open door.
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
Feb 02, 2008 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Dishwashers Logo
662 people viewed this question
Top GE Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Bill Johnson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
