Question about Kenmore Kitchen Ranges
The F15 error does indicate that you have a problem with the electronic oven control board in the console. That F15 could be caused by pressing the buttons and holding them down in the Sabbath mode. If the control was in Sabbath mode and does not show the F15 code after disabling that feature then the oven should work normally. If the oven is not in the Sabbath mode or you do see that F15 code after disabling the Sabbath feature then you will probably need to replaced that electronic oven control board. I recommend that you have a service technician complete that type of repair in your oven
Posted on Apr 06, 2018
SOURCE: F90 Err on Kenmore Elite
the F90 fault indicates that the maximum time allowed for oven door unlock was exceeded. The control attempted to unlock the door. The door lock motor or mechanism failed to unlock the door within the maximum amount of time it is allowed to be energized by the control board.
It is unlikely that you will be able to reset this fault code. You can try to completely disconnect electrical power and leave it off for 5 minutes. After reconnecting power, the fault code will probably reappear since the control will still detect that the oven door is locked. The only way to clear the fault code is to disassemble the range and repair or reset the oven door lock assembly. You will need a service technician to complete this repair.
Good Luck
Posted on Dec 30, 2008
SOURCE: Kenmore Elite slide in range F30 error
I had the same F30 error problem but fixed it. On my professional series Frigidaire, there are 2 resettable red button locations. I discovered that only one is in the rear of the oven. After going to the breaker box and shutting off the power, pull out the stove enough to work, unscrew the rear screws (I didn't unscrew all of them, just enough to work back there). The small red button is on a small black round piece with two purple wires feeding to it. That was not my problem. Mine was the other red button behind the control panel. Pull off all 4 knobs, unscrew by hand the large black rings that are underneath the knobs, pull out the whole panel. Look back and right (below where the right knobs were located) to find the 2nd red small button. Push to reset. Check this one first since it is easier to do.
Posted on Feb 17, 2009
SOURCE: my kenmore elite electric slide in range displayed error and F13 and the oven won't turn on
i phoned Sears about error code f13 on a gas range, and was told to unplug the range for 30 minutes. i think she meant 30 seconds - to reprogram the microchip. i unplugged it for 15 minutes or so, then reconnected, and it worked.
Posted on May 28, 2009
SOURCE: what is error code e1?
The E1 displayed indicates the thermistor is open and needs to be replaced.
The connections can be loose but the most likely cause of an E1 error is a bad thermistor.
The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
If you're comfortable and confident in your do-it-yourself skills and have access to a volt/ohm meter you can check and replace this part yourself.
The thermistor is available from the following: www.searspartsdirect.com
Enter your model # in the appropriate box to get a full parts break-down and diagrams.
To access the thermistor see the image below.
Remember to unplug the dryer from power first.
The thermistor will have a black and red/white wire on it.
You can check continuity across it with the meter and if the circuit is open then the thermistor needs to be replaced.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
The thermistor -may- check ok when cool and freak out when warm!
http://media.fotki.com/1_p,wkrsfrgsskrbttbxgtqsskgwtqkq,vi/wbsdwtgwgxwrgbbgsgs/1/1303472/5961857/image6767img-or.gif
HE3 Dryer: http://media.fotki.com/1_p,wbfbgrrwtrrkfttxgtqsskgwtqkq,vi/kgwgwwwdkxkfkkgwgqs/1/1303472/5961857/image7127img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
SOURCE: Kenmore Elite slide in range model # C790-440732
I have the same problem with my Kenmore F23 code will not bake but the broil works?? What the heck?
Posted on Nov 16, 2010
Sep 07, 2018 | Kenmore Kitchen Ranges
Dec 30, 2015 | KitchenAid Kitchen Ranges
Nov 24, 2014 | Kenmore Ovens
Sep 18, 2014 | Kenmore Kitchen Ranges
Sep 10, 2014 | Kenmore ELITE 790 30 FREESTANDING DUAL...
Dec 08, 2012 | Kenmore Elite Sears & Other Brands...
Jul 18, 2011 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Dec 26, 2008 | Kenmore Elite 45986 Front Load Washer
Jul 09, 2008 | Kitchen Ranges
1,510 people viewed this question
