Health & Beauty Logo
Question about Norelco Health & Beauty
Norelco 900rx schematic
My Norelco 900RX shaver charging light use to be a constant green when charging now it flashes real fast all the time. Is a schematic available ?>
Posted by bfong129791 on
4 Related Answers
Anonymous
  • 11896 Answers
SOURCE: my cordless norelco hold a 25 min charge
Buy a plugin for cell phone or electrical device that has the same voltage output as the battery. Then cut the end off and wire it directly to where the battey connecctions go to
Posted on Jul 07, 2009
freetek
Steve Allison
  • 5569 Answers
SOURCE: Norelco shaver 6866XL won't charge, light glowsred
The battery is probably one with multiple cells and one (or more) of them has shorted preventing the total from reaching a voltage that appears as fully charged.
If the cells are Ni-Cads, this is a common problem with them and when a battery-operated item of mine fails, I replace those older types with NiMH cells if the battery compartment can accept them.
I have 'restored' countless NiCads over the years by 'zapping' them with a fairly high current for a second or two; voltage isn't important as long as it is in excess of 2-3 volts but the source should have a few amps capacity.
This type of cell grows 'whiskers' that will cause them to short completely or develop a path that causes them to self-discharge faster than normal.
Posted on Oct 16, 2009
Anonymous
  • 10865 Answers
SOURCE: Using Norelco 3801XL shaver in Europe
hello. In order to use these devices in Europe you need a power adapter. Go to this link to learn all about it
http://goeurope.about.com/od/electricityineurope/tp/power_adapters.htm
Joe. Please rate my answer as very helpful. thank you
Posted on Mar 25, 2010
Bruce Robin
  • 300 Answers
SOURCE: Norelco shaver doesn't recharge.
If the shaver won't hold a charge it usually means that the batteries need replacement. This requires disassembly and soldering skills. It's not hard to do but if you're not handy with a soldering iron a shaver repair shop can do the work for you. However, if you have to pay to have it done and if the blades are more than two years old and need replacement, you might be better off just buying a new shaver.
Posted on Jul 05, 2010
Green light on Norelco shaver 4807 xl flashes
The flashing green light indicates that the shaver is fully charged
2answers
Is HQ9 compatiable with HQ55?
No, philips norelco HQ56 replacement heads compatiable with HQ55
philips norelco HQ56 for norelco 100db, 110db, 1323, 2005c, 200sc, 300sx, 3405lc, 3601x, 3604x, 3605x, 3801xl, 3805xl, 3865xl, 400dx, 410db, 4401lc, 4402lc, 4403lc, 4404lc, 4406lc, 4413lc, 4414lc, 4417lc, 4601x, 4602x, 4603x, 4604x, 4605x, 4606x, 4607x, 4608x, 4625,x 4805xl, 4807xl, 4816xl, 4816xld, 4817xl, 4817xld, 4821xl, 4825xl, 4825xld, 482xl, 4845xl, 484xl, 4852xl, 4853xl, 4861xl, 4865xl, 486xl, 4885xl, 500rl, 501rl, 505rl, 5426lc, 5625x, 5812xl, 600rx, 605rx, 6423lc, 6424lc, 6613x, 6614x, 6615x, 6616x, 6617x, 6618x, 665rx, 6843xl, 6844xl, 6853xl, 6854xl, 6856l, 6856xl, 6863xl, 6940lc, 6945xl, 700rl, 705rl, 710rl, 715rl, 720rl, 725rl, 750rl, 800rx, 805rx, 815rx, 825rx, 835rx, 850rx, 875rx, 885rx, 885rxac, 895rx, 900rx, 905rx, 915rx, 935rx, 945rx, 950rx, 955rx, 965rx, 968rx, 975rx, 985rx, hp1318, hp1319, hp1327, hp1327d, hp1328, hp1328e, hp1328s, hp1337, hp1337c, hp1601, hp1602, hp1604, hp1605, hp1606 and hp1608.
2answers
Are Norelco HQ9 Blades interchangeable with HQ55 blades?
philips norelco HQ56 replacement heads compatiable noelco HQ55 blades.
Just bought a norelco 8240 xl razor . when i charge it the light blinks green off and on. how do you know it fully charged. it was charged for 12 hours and was still blinking. is this normal.
The light blinks when the shaver is fully charged. This information is sated in the user manual that came with the shaver. If you do not have the manual you can view it at shaveroutlet.com. See link below
https://shaveroutlet.com/index.php/aitdownloadablefiles/download/aitfile/aitfile_id/93/
1helpful
2answers
I have a Norelco arcitec 1050 electric razor and I have lost my instructions. What does it mean when the red light starts flashing (picture of razor heads)?
Means that the the replacement heads indicator flashing, it's time to replace new heads. That Norelco RQ10 heads for Norelco arcitec 1050 electric razorreplacement parts.
3helpful
3answers
A red warning light is flashing...looks like the razor heads icon...what does this mean??
It's means that you should change new replacement heads, that Norelco RQ10 shaving heads for Norelco Arcitec Electric Shaver heads replacement parts.
1helpful
Purchased Norelco shaver 7810XL. Instructions state to charge for 4 hours prior to first use. Green lights began blinking, indicating full charge, after less than 2 hours. Do I continue charging after...
Simply follow the instructions and charge for a full 4 hours the first time. On subsequent charges, unplug when the light blinks after about 1 hour
Norelco 8240 does green light blinking mean full charge?
The flashing light is charging. At full charge the light is initially steady then goes out.
1helpful
3answers
Red light at bottom flashes even when razor ids fully charged. What can causrethis?
When the battery is almost empty (when there are only 5 or fewer shaving minutes left), the battery symbol lights up red.
Make sure that the battery does not have a memory effect. What I suggest is taking the shaving head unit off and running the shaver till empty, then recharging. Check if the red light is still flashing.
There's also a head indicator at the bottom of some shavers.
To remind you to replace the shaving unit, the shaving unit symbol flashes (all types) and you hear a beep when you switch off the shaver (RQ1090 only). This happens at the end of 7 successive shaves to remind you to replace the shaving unit.
Without knowing what model you have it's difficult to diagnose further.
Top Norelco Health & Beauty Experts
Robert McClure
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
