I would have to say the version of Kodi you are trying to install is not compatible with the Android Firmware. To remedy this, you need to go to a wesbite called MYGica.co.za and download the Kodi Kyrpton 17 APK. This is basically Kodi Krypton hacked to be made to work on the older Android OS. Download that then you should be able to install Kodi without any errors. After that you will want to install a build. To check out a list of the best kodi builds for 2018, check the link below. Theres full tutorials on there with screenshots to help you through the installation process. Anyways hope this helps.
Best Kodi Build List for 2018 Must Read Before Installing BestBox
SOURCE: Getting code 10 error
Uninstall and then reinstall the software from the CD - this is the fix suggested by both the manufacturer and Microsoft for Code 10 errors.
-Tha Mp3 Doctor
SOURCE: Drive not working--error code 39
Follow this article to fix the issue.100% Guaranteed
http://social.technet.microsoft.com/forums/en-US/itprovistahardware/thread/bd9763de-6141-45ea-990b-70c207fe3fb6
SOURCE: driver won't download intellinet ethernet driver os 98
Try to manualy specify the path to your driver using driver update.
SOURCE: I have a emachine T3646 and the cd drive will not
try this one:
if you are using windows XP
- click start
- click run, in the run type in regedit
you will see a registry editor window
in the registry editor window
- click the + sign at the hkey_local_machine
- click the + sign of system
- click the + sign of currentcontrolset
- click the + sign of control
- click the + sign of class
there will be bunch of random letters and number under that control
try to find this one
{4D36E965-E325-11CE-BFC1-08002BE10318}
if you click this check if you will be able to see DVD rom at the right side of the registry editor window
you must delete the upper and lower filters
after that restart the computer and try to put in dvds
for vista or win7
- click start and type in the start search regedit
after this just do the same thing with the win xp instructions
if still doesnt work try to uninstall/reinstall the cd/dvd driver
try also to update the DVD codec. you can also try to download the most updated windows media player, power DVD or any software/program that have dvd codecs or that acts like a player for DVD
i hope this works.
SOURCE: Have Windows 7 Home Premium (64-bit)on a new HP
Not compatible or not working well with windows 7?
(make your program/application run with windows 7)
Maybe, It doesn't work because the driver/application you installed is
for other versions of operating system. I am also using windows 7 like
you so don't you worry, You can still use your old installer/driver from
other versions of operating systems. Just remember that before
installing any program in a windows 7 Operating System Computer, Use
"troubleshoot compatibility". Right Click the Icon of your program
installer/application first, then choose "troubleshoot compatibility".
This will allow you to choose on what type operating system your program
will run. Just reply back if it still doesn't work.:D rate and vote
for me:))
https://bestandroidtvbox.com/best-kodi-b...
