Heating & Cooling Logo
Jim Spear Posted on Apr 06, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
With CT87K. Temperature set doesnt match actual temp by 4-5 degrees
Thomas Woodburn
Level 3:
  • Heating & Co... Master 2,638 Answers
  • Posted on Apr 06, 2018
Thomas Woodburn
Level 3:
Answers
2638
Questions
Helped
1250476
Points
7008
Be sure to seal hole where wire comes through wall.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Bonded Repair
Level 3:
Master:
  • Master 407 Answers
Bonded Repair
Master
Level 3:
Master:
Answers
407
Questions
0
Helped
91236
Points
1065
On some you can calibrate,or it may be location where mounted
5 Related Answers
Anonymous
  • 700 Answers
  • Posted on Jan 25, 2009
SOURCE: Honeywell T87f 3855 Doesn't Activate Heater
thats becaue you need more than this zone working like you said about the master/slave this zone is a slave.
Anonymous
  • 767 Answers
  • Posted on Dec 17, 2009
SOURCE: the thermostats current setting does not match the
Sounds like you have a problem with the furnace try turning the power off to the furnace and then turn it back on to see if this will get it to run. If it has a sight hole in the bottom door look to see if there is a flash code. then take off door and see what the flash code represents as the problem.
spacerook
  • 130 Answers
  • Posted on Jan 16, 2011
SOURCE: My new Honeywell Round Heat Only Thermostat CT87K
Make sure it is level, there are level marks on the base
John Fernie
  • 52 Answers
  • Posted on May 20, 2011
SOURCE: The temp. setting doesnt match
Without more info i can only give general info. ISOLATE MAINS POWER BEFORE REMOVING PANELS
It sounds like one of several possible problems, temp control switch they use in some models two terminal over heat control components, or temp prob, the first type is a metal case with two terminals, you may see black on this if not a test meter will be required. It should conduct through the terminals, not the case to the terminals, Impedance setting low on meter. The second type is a bit tricky to test and is generaly controlled by an electronic circuit, it is poss it could be one element blow inspect them a Black Grey spot blow out or a bulge on the element surface. This can cause temp problems.
Hope this has been helpful
John
espressonist
espressonist
  • 1711 Answers
  • Posted on Aug 27, 2011
SOURCE: Danby model DBC514BLS. Temp
The problem you describe it seems to be from a dusty condenser so you need to remove the grill on the bottom and also at the back and using an air blower, or a vacuum and brush in order to clean the condenser coil for all the dust . The dust is blocking the sorounding air to cool down the condenser and litle bu little is loosing its efficinecy. Of course this is the most frequent case by 90% so you have to do this in order to confirm thatis not due to any part mulfaction like thermostat or other parts.
1helpful
Riello 40 gasG900 burner that will ignite but when oven reaches temperature it turns off completely. After temp drops by 4 degrees it turns back on and reheats back to temp then turns off.Why is this?
that would be normal. if it didnt shut off, it would go above the set temperature. the heat is either off or on. it cant me in the middle. it turns 'off' so that the temperature doesnt go too far above 250. when it senses the temperature falling too low below 250, it heats it up again.
Sep 03, 2017 • Ovens
2answers
Heater temp is 78 the water temp 68 how do I reset heater temp to match pool temp.
Sounds like a faulty temp sensor. Check it for debris, clean it good and see if that does it. If not try replacing it.
Jun 02, 2015 • Pool & Spa
Trying to set temp on honeywell t-stat
I believe what your experiencing is the 75 degrees is the hold temp position...the display then reverts back to the actual room temperature...it doesn't mean the set temperature changed back to 65 degrees. Try to reprogram the thermostat schedules, and try not to use the hold function...just the temporary hold. (which is bumping the programmed temperature up or down until the next programmed period)
Remote is inaccurate
did you change the batteries ?
Solarium 105 pool heat pump, how to unlock display
This may prove helpful:
Rome Solarium 125 Service Mode:
Entering Service Mode
1. Hold the Hand button for 10 seconds until "Loc" is displayed
2. Press and hold the up arrow button until the numbers starting counting upward rapidly, stop at 50
3. Press the Hand button to enter Service Mode
Calibrating the Water Temperature
1. Enter service mode as per above instructions
2. Scroll to "tSC" (temperature sensor calibration) using up or down arrow buttons
3. Press the Hand button to calibrate the sensor, the current calibrated temperature will be displayed
4. Adjust the current displayed temperature reading to match the actual desired temperature using the up and down arrow buttons (leaving a few seconds between adjustments for sensor to use new setting)
For example, if tSC display reads 88 but the pool temperature is actually 86, press the down arrow twice
4. Once the selection is made, wait 10 seconds for the display to timeout and go back to the normal display
Oct 06, 2012 • Pool & Spa
Temperature fluctuates in bake setting. Temp on display does not match real oven temperature.
as long as your measured temperature is within 15-25 degrees of shown temp, then it should be ok. remember the temp in the oven will be different from top to bottom.
My nonprogrammable Honeywell thermostat th5110D is no matching temperature settings (desired and actual). There is about 4 degrees difference. I have looked at the manual and reset the system and changed...
Your thermostat is reading the temperature where it is located.
If it is located next to a heat source maybe it is picking up that added heat .
Try relocated your thermostat
Whirlpool range 465 model # sf369lemo oven temperature
no stove holds a true temp they all fluctuate temperature depending on how well it is insulated.
When this thermostat is in the HOLD position, which cancels the programmed feature, I set the temperature to 72 degrees and the furnace runs until that 72 degree temperature is obtained. Now the thermostat...
If you still have the instructions for the thermostat, then it will show you how to get into the menu and set the swing on the temps. I would try to explain off the top of my head, but its actually quite a bit off numbers to remember. Hope it helps somehow.
Top Heating & Cooling Experts
Paul Carew
john h
