Question about Hotpoint Washing Machines
Hotpoint wf860 how do i get rid of TEST on display
Posted by raesinclair9 on
Terry
  • Hotpoint Master
  • 11,377 Answers
5 Related Answers
Anonymous
SOURCE: Hotpoint ultima wf860
hi, i have the same machine..i have a feeling it does this annually to make you call an engineer. to reset it do this; hold the 'start' button until all lights display, then press 'start' again. hold the 'start' and 'on/off' button together until it reads d-end or d-off. it doesnt always work 1st time so keep trying, good luck x
Posted on Nov 14, 2006
BIGIFA
  • 27 Answers
SOURCE: hotpoint wf860
the applionce is in demmo mode and running a test cycle so you need to cancle the cycle first by holding the start reset button until all the screen iluminates(88:88) now you need to disable the demo mode by holding the start cancle and the on off buttons together until you see D OFF in some cases you may need to hold the button to the top left of the screen and the start and on off buttons but this will sort it
Posted on Feb 22, 2008
Anonymous
  • 100 Answers
SOURCE: my hotpoint washingmachine WF860 comes with the message tESt
it's on test mode for the factory. this comes on if you hold the on and start buttons together. can be reset by turning on while holding both on until dOFF appears.
Posted on Jan 27, 2009
Anonymous
  • 53 Answers
SOURCE: when I start a program, It displays
try this - press start, press start again. Now press the on/off button and the start button at the same time and hold them down for 5-10 seconds until the display shows d-end or d-off.
Posted on Oct 31, 2009
Dave Smith
  • 86 Answers
SOURCE: where is the filter on a hoitpoint ultima wf860
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The filter is under the rear of the machine inside the sump hose. Remove the lower rear inspection panel and tilt the machine forward, keep it tilted by placing a tin of peas or something under it at the rear. Now put a shallow bowl or dish under the sump to catch any water that may still be it the drum and remove the retaining clip. Pull the hose free from the tub and the filter is inside. (Work safe and remove the power plug from the wall before commencing any repair) For more tips on repairs use this link selfix-uk
Posted on Mar 11, 2010
Hotpoint_wt965
hold down the two buttons untill the test display goes then you will hear it pump out and let go if that does not work you have a fault on your timer module let me know
Nov 08, 2011 | Hotpoint Ultima WF860 Front Load Washer
Washing machine it test mode
To exit the DEMO/TEST mode, press and hold down the "On/
OFF" and "Start/Cancel" buttons until "d off" is displayed
Mar 14, 2010 | Hotpoint Ultima WF860 Front Load Washer
Test Error
Hold In on/off and start buttons together for 10 secs.
Feb 20, 2010 | Hotpoint Ultima WF860 Front Load Washer
When I start a program, It displays
Oct 31, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WF860 Washing Machine displaying error F-65
there is no F65, perhaps it's F05 which means it will not empty water (not oumping out). Should av gone to specsavers !
Apr 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
HOTPOINT WF840P SHOWS TEST IN DISPLAY AND WILL NOT OPERATE
turn on while pressing the on and start buttons at the same time until 'dOFF' appears.
Feb 24, 2009 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint washingmachine WF860 comes with the message tESt
Jan 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint ultima super silent displays 'test' but dnt run cycle
its in factory test mode, this can be set by pressing the on and start buttons together. to reset, turn on while pressing the on and start together until dOFF appears
Test
Hi i have a hotpoint wd 860 washer dryer the display is showing f 08 heater relay cannot be activated.can you please tell me how i can fix this problem myself.Thank You
Jan 04, 2009 | Hotpoint Ultima WF860 Front Load Washer
WF860 saying test on the display
Is this machine new and this is the first time you have used it?
If yes - you will need to let it complete the TEST cycle fully before it will be useable. (do not interupt - takes 60 to 90 mins)
Apr 13, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
67 people viewed this question
Top Hotpoint Washing Machines Experts
James Hehling
James Hehling
Level 1 Expert
gbob59
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
