Question about Water Sport
I’m trying to buy a new bathing suit. According to the size chart my bust and hips are one size and my waist is another. Do I go with the bust and hip size? Thank you
Posted by Deb Deuel on
Vernon Taylor
  • 6,665 Answers
Lots of ladies share your problem which is not easily overcome, especially if your waist is larger rather than smaller...
You really need to try on several costumes to find the best fit and in the lower price ranges you are likely to discover considerable variation between garments of the same theoretical size.
This is because the fabric tends to be cut to a tolerance rather than an exact size.
If your waist is smaller I suggest you choose a garment that provides the best fit for your hips and bust but if your waist is larger, practically speaking, you will have little choice and will need to buy to suit your waist and either compromise on the bust/hip fit or have a seamstress make a few slight alterations.
Posted on Apr 06, 2018
Gregg Mahin
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 64,517 Answers
Hi, Deb This is a rather bizarre question coming from a woman and I normally don't fool with such nonsense, but in my humble opinion, I would go with the bust and hip size. Good luck and have a wonderful day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
1 Related Answer
casouzaj
CARLOS R SOUZA JR
  • 1118 Answers
SOURCE: Ideal waist size. According to Dr,Aaron R Folsom
The relation is 0.8 (or 4/5). If it is kept linear, for 35" hips, the waist would be 28".
Cheers! Carlos
Posted on May 13, 2010
Tip
How to Choose the Right Swimwear to Suit Your Shape
Bathing suits and bikinis are a source of great stress for some people.
It doesn't matter how good the celebrities look in the magazines in their designer bikinis - most people worry a lot about the way they look at the pool.
I've written a guide below for different body types so you can work out what kind of swimwear will best flatter your individual shape.
Firstly you need to read through the different types and figure out what category your body shape fits in to.
Ultimately you should be sitting by the pool feeling good about your swim wear and not be feeling self conscious.
Big Chested:
  • If your top half is much bigger than your bottom half it can be really hard to find something suitable.
  • Go for mix and match separtes or a costume that has gathered fabric at the waist. You're looking to create a division between your chest and hips.
Small Bust:
  • You need to look for bikinis that play up the bustline. Bright patterns and bottom halves that are high waist will help make your legs the focal point and yet still be feminine.
Pear Shaped:
  • If you're pear shaped you can use cut away shapes and and unusual shapes to flatter that parts of your body that you are confident with ie your waist whilst drawing attention away from wider hips.
Large Size:
  • Plus-size women are enjoying swim wear that comes with a skirt attached. examples are swimdresses or using a sarong. You can them emphasize cleavage etc but not overly focus on areas you might feel self conscious about in a swim suit such as thighs.
  • Avoid over patterned materials.
on Jan 02, 2014 | Water Sport
Can you advise me how to us Simplicity pattern 8065. I am not sure about the sizing , never used pattern girls plus. I need a size 10-12Chest:69 cm, Waist 61 cm, Hips 74 cm.
You need to study how to alter a pattern to fit your measurements. Most often, it is recommended to purchase a pattern to fit the bust and then alter the others to fit. You can go to the library and check out some pattern fitting books.
The best thing is to purchase some inexpensive fabric, ie muslin, and use it to make a trial garment. Making a trial garment will help you fit it to your body plus you don't waste your nice fabric on something that won't fit.
The Merits of Basic Fitting Pattern Threads
Adjusting Patterns for Fit part 1 The Sewing Geek
Jan 04, 2017 | Simplicity Sewing Machines
Pierre cardin size chart
If you want to buy this shirt online it be better to measure your chest and waist + your height and ask support on the pierre cardin site, do your parameters match their size XL
Aug 09, 2014 | Clothing
What does the 44 mean? Is that hip size??
if it is a 7x size, then the 44 would/shoukd be the waist size. Hope this helps.
Jan 29, 2014 | Rago Womens Plus-Size Panty V-Leg Beige...
How high should a ballet bar be fixed on the wall?
A general rule of thumb is that a barre should be placed at a level between the users hips and waist. The standard height is said to be 3.5 feet; however if you are teaching younger children, you will need to adjust the height to suit them.
Aug 26, 2012 | Gibson Dancing
Water Sport Logo
483 people viewed this question
Top Water Sport Experts
Marvin
Marvin
Tom Chichester
Bill Boyd
Are you a Water Sport Expert? Answer questions, earn points and help others
