Question about Firearms
Recently inherited a Marlin 39-A, serial D 3428. Could you tell me what year this was made? Thanks!
Posted by Stephen Ahlgrim on
Marvin
    Top Expert:
  • 85,239 Answers
Sorry we do not have access to that info at this website.
Posted on Apr 05, 2018
5 Related Answers
Sal De
  • 2699 Answers
SOURCE: I inherited a March 1990 Sub-Zero (Model
if it's a side by side open both doors and look up,if you see three screws remove them or if the fridge door is on top open it and remove screws if they are there going up into top panel,then tilt the top panel down from the top and remove the springs,then remove the top front panel,on the left side you need to remove the two fillips screws and remove that panel,unplug the evap fan motor wire harness,then vac out any lint and dust you see on the coil and in the cabinet and off of all the walls and ceiling,then cover the opening with a towel, a shop vac works great because it blows on the other end,set it on blow and blow through the coil on the side opposite the fan and the towel will hold all the dust inside the cabinet,when you work on the coil use the brush attachment so you don't damage the coil,the fins bend easy and it will stop the air flow,stop blowing and vac up all the stuff that blew out of the coil,keep doing this until nothing blows out,then blow through the fan side,then vac up all the stuff,keep doing this until it looks clean and nothing is blowing out of the coil,you can stick a light on the side opposite the fan and look at it through the fan side,if you can see the light clearly then the coil is clean.do this once every 6 to 12 months and you'll be fine.hope this helps you out,
Posted on Jun 16, 2011
strech3030us
Strech
  • 1562 Answers
SOURCE: I'm trying to see what year my marlin lever action rifle is.
1883
Found here:
http://oldguns.net/sn_php/marlinlookup.php
Posted on Mar 28, 2014
strech3030us
Strech
  • 1562 Answers
SOURCE: What year was marlin model 55. Serial number
1979
On Marlins made from 1948 and later, subtract the 1st two digits of the serial number from 2000.
Serial number 21615408
1st two digits = 21
2000-21 = 1979
Posted on Jul 13, 2014
Fahr Quad
  • 774 Answers
SOURCE: What year was my marlin .22 modle 39 made and what is the value of it? The serial number is 5503
Your Marlin model 39 serial number 5503 was manufactured in 1883. I strongly suggest getting the gun appraised by an expert before trying to sell it. I have run across prices from as low as $99 and as high as $7500 at Gunbroker.com.
Posted on Nov 05, 2014
gbob59
  • 3063 Answers
SOURCE: What's year was manufature marlin 22 octagon model39a serial 27127775
google MFG website. Model serial
Posted on Mar 28, 2015
Date my marlin 1881 in 45-70 S/N 13496
Hello, Timothy -
I see that similar questions have been posted and answered on the Marlin Firearms Owners Forum:https://www.marlinowners.com/forum/forum.php
I suggest you post your question there, as the forum members will be most familiar with Marlin firearms.Registration (free) will be needed there for you to login and ask your question.
Best wishes.
Oct 27, 2018 | Firearms
The last bullet in the tube of my model 60 marlin won't slide in to load. all other bullets other than the last one load and fire. the last bullet can be hand loaded and will fire
Could need a new spring in the magazine tube.
Ebay has complete inner magazine tubes.
search for Marlin Model 60 .22 Inner Magazine Tube
Aug 20, 2018 | Firearms
What years was the marlin model 36 lever action .22 made
The Model 36 was introduced in 1936 by Marlin Firearms as an improved version of the Model 1893. Around the time of the First World War, Marlin dropped the "18" and started calling the Model 1893, the Model 93. But no significant change in the gun's design took place. In the period between the wars, metalurgy was changing, as were manufacturing techniques. So Marlin upgraded the Model 93 and re-designated it the Model 1936. This moniker lasted only one year, and in 1937 it became the Model 36.
Model 36s were made until the Second World War. In 1948, the Model 36 was redesigned and modernized again and was given a round bolt to replace the square . The model number was again changed to Model 336. Lots of versions and lots of small changes have been made since, but variations of the Model 336 are still in production.
Pete
Apr 06, 2017 | Firearms
Firearms Logo
198 people viewed this question
Top Firearms Experts
jws1013
Kardoc
Joseph Coppeto
Joseph Coppeto
Are you a Firearm Expert? Answer questions, earn points and help others
