I have a model 52RV535U and half of the screen locks up and has vertical lines. at first it was intermittent and now it is all the time. Do I need to replace the main control board or the T-Con board?
SOURCE: vision 42 inches plasma tv
It sounds like there is a problem with the tuner inside the television. Your best bet is to send it in for service.
SOURCE: Philips LCD model 26TA1000, vertical lines and blank white screen with no picture
it would be easier to find it stripped from a damaged set on ebay.
I see several there but need the part number to search
of course you may purchase that and find it to be the lcd driver.hopefully not.
SOURCE: Hitachi Model CMPAS14V vertical line
anyone experiencing this problem should get in touch with Dave at [email protected] . he sold me a fix for this problem, for much less than the $400-$500 we were told it would cost to fix it. Dave not only solved the problem but provided the best customer service and support I have ever received. ABSOLUTLY the best money I ever spent, saved my T.V. Get in touch with the confidence of knowing he will help you as he did me. Thanks again Dave!!!
SOURCE: I have a Samsung Ln32A450c1d
Basically it is problem of LCD Panel (screen) however some times T-Con board replacement fixed the issue (T-Con board is part of lcd panel but some part shop sell it separately). Main board is not related with this kind of problem.
Required T-Con board is available in ShopJimmy.com (click the link to view available boards)
If T-Con board replacement does not solve half screen vertical lines problem then LCD Panel will be replaced and it would cost approx new tv price.
Hope this info will help.
Thanks.
