Question about Kenmore Kitchen Ranges
How to fix kenmore Model # 790 oven grange door light flash door lock and stove beeps
Posted by Michael Ortiz on
5 Related Answers
Fixe_You
Jalal Sordo
  • 1800 Answers
SOURCE: kENMORE GAS STOVE MODEL 790-71105893
just the sears bring proper sears and replace them after u remove the old ones
and u need a ignition panel for the electric starter
rate me sir
if this not helping tell me and i will hep u further.
Posted on Aug 18, 2008
Anonymous
SOURCE: Kenmore 790 Oven Locking mechanism problem
I had the same problem. Open the oven door. Press and hold the light switch. You will hear the door lock move back into the correct position. Hope this fixes your problem. This has happened to me twice and holding the light switch always works.
Posted on Sep 25, 2008
Anonymous
hold down the stop/clear button for 3+ seconds
Posted on May 25, 2009
Anonymous
  • 572 Answers
SOURCE: Kenmore oven model 790-46593500 shows error 91 and
if u were selfcleaning it probably damaged the doorlock
Posted on Feb 11, 2010
seth adams
  • 1531 Answers
SOURCE: Flashes F-1 and beeps
this is usually a problem with your main control board and it needs to be replaced
Posted on Feb 23, 2010
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
www.youtube.com/watch?v=U0VcfMJPaiY
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ...
www.shopyourway.com > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
Kenmore electric range model 790 door lock light flashing
Hi, When door locks, This is when oven is in self clean mode. After the heat has cooled down the door should release again. If this does not work try turning the power off to the stove (breaker) This should reset the stove to normal. Call a repair man if this continues. Good luck.
Jun 01, 2015 | Kenmore Kitchen Ranges
Kenmore 790 electric range
The F1 code is a problem with the very sensitive electronic panel inside and it probably got taken out when the socket shorted out. Here is the part to order. There is a video on that same parts page to show you how to swap the board out.
Aug 18, 2013 | Kitchen Ranges
Feb 23, 2010 | Kenmore 95320 / 95321 / 95322 / 95324 /...
Self cleanning oven - door is lock and I can not get it to open
if you open the lid on your stove,you will probably be able to reset the
switch manually (the latch).with the lid up its located toward the front
behind the safety latch.(by no means attempt to force,bypass,or disable this
switch)this is a safety feature designed to protect you from the high temps
generated by the cleaning cycle.hope this helps.thanx for using fix-ya
Try this, and let me know if it worked, I am trying to help someone else with the same problem, that stove is Model, 790
Mar 07, 2009 | Kenmore Ovens
Jan 13, 2009 | Kitchen Ranges
Jul 14, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Elect Built-IN Oven Model 790
You don't say what specific F code error. If it is an F7, go to the following link for my solution.
http://www.fixya.com./howto/h155060-dreaded_f7_error
I have shared my fix with over 1570 folks and most report success. I hope that it works for you too. Please let me know at:
[email protected]
Feb 23, 2008 | Ovens
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
42 people viewed this question
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
