No it dos not shaw
That means just what it tells you
the PC is dead, PC video dead or video cable unplugged , dog chewed it , pins bent or plugged in wrong on 1 or both ends.
or monitor not selected to the correct input port (OSD)
PC power lamp glowing not amber or blinkikng
PC fans spin , PSU fan and CPU both
if PC has GPU card in PCI-express slot it must be use those ports only for video.
PC not beeping
PC not texting errors post.
PC not blinking codes on LED or caps lock or POST ERRORS !
NO PC told
PC dead.
PC not stuck in sleep mode , hold PC power button for 10 full seconds to end it, (cold boot that is)
test monitor on end good PC? yet?
SOURCE: new monitor only shows my desktop image. and nothing else
it is not monitor problem as it is showing desktop. there is problem in setting of monitor or monitor Configuration is not proper. please refer manual which you must have received at the time of purchase.
SOURCE: remove cover viewsonic vx 900 monitor to change bulbs
How do you change the bulb on viewsonic monitor 19" model VX900? Where can I get a new replacement bulb?
iv no sound coming from my monitor speakers but if the child plus a earphone into the back of my pc he can hear sound can u help me plz nadine1 :)
SOURCE: i can connect my new acer X203H LCD monitor to computer
Open your cpu cabinet.
Refix RAM memory .
Pull cmos cell from motherbord for 10 minutes.
Pull processor fan and processor then refix both clean dust from all parts.
Remove pci cards from pci slot then check.
Let me know if you need more assistance.
Thanks.
SOURCE: Monitor shows on receiving signal, will not display image.
The Viewsonic VX2235WM has a known issue with the power supply going out. The flashing power light or no picture is the classic symptoms of this issue. Check out our web site at: www.ccl-la.com. We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: [email protected]
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Testimonial: "Took a full year to get a response, but it was worth the wait, thanks very much for taking the time to respond."
