SOURCE: feed dog switch
Did you turn the handwheel? The feed teeth will not come up until the machine is operated. Run it a few stitches and they will come up.
SOURCE: Feed dogs do not come back up after lowering
Are you talking about the feed dogs or the presser foot. Either way, if you moved a lever to lower them, there is probably a screw that either fell out or has become loose that holds the linkage to the lever.
SOURCE: Feed dog lever not working on my Kenmore 385 24 stitch machine
I surfed around this site for various suggestions, finally took the bottom plate off and cleaned and oiled all the parts along that rod that goes right across (think it's a drive bar that rotates). Ran the machine without thread in for a few minutes to let the oil soak in. Machine now works fine.
SOURCE: husqvarna optima 620 feed dog won't stay raised
If you have switched to "UP" position and turned handwheel one full revolution with no result it may be that
1. There is lint under the needleplate preventing it from rising fully....clean it out !!
2. There is damage to the linkage and will need to go in for visual appraisal by technician....ask for a quote on repair before they do anything.
