Question about Audio Technica Audio Players & Recorders
I need help putting the belt on my audio technica at-pl50. can you please help ?
4 Suggested Answers
6ya staff
SOURCE:
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: belt is off my audio-technica turntable at-pl50
WASH YOUR HANDS FIRST! Any oils on the drive belt may cause slippage.
This is from the manual:
A) Remove the record mat from the turntable platter
(Fig. 10a). Through an opening in the
turntable platter, visually inspect to see if the drive belt
is around the motor pulley (Fig. 10b).
B) If the drive belt is not around the motor pulley: Lift
and remove the turntable. Place a thumb into each of
the left and right openings on the turntable platter; and,
using the fingers to press down on the turntable housing’s
surface, pull the platter straight up (Fig. 10c).
Avoid pressing on the tone arm.
C) With the turntable platter bottom side up, place the
belt along the outside wall of the turntable platter's
drive rim, making certain that the belt is smooth and
flat all the way around (Fig. 10d).
D) Put the turntable back on the center spindle, make
certain it is fully seated, and align one of its openings
over the motor pulley position.
E) Through the opening, carefully hook the turntable
belt with a finger or with the original red ribbon (never
use a sharp object) and pull the belt over the motor
pulley (Fig. 10e). Make certain the belt is not twisted
between the pulley and the platter’s drive rim.
F) Put the record mat back on the platter.
G) While holding the tone arm in its rest position,
slowly turn the platter by hand clockwise at least 10
rotations to clear the mechanism’s automatic cycle.
Posted on Apr 24, 2009
Anonymous
SOURCE: Audio Technica AT-PL50 Stereo full automatic turntable system
Try winding the turntable at least ten times clockwise per the instruction manual to reset the mechanism.
Posted on Jul 26, 2009
Anonymous
  • 69 Answers
SOURCE: My Audio-Technica at-pl50 is running just a bit faster than 33rpm
your belt has http://www.needledoctor.com/Online-Store/Turntable most likely stretched? go to this site for a replacement belt? good luck
Posted on Sep 15, 2009
How do you replace the belt?
Lift off rubber table mat..then lift off turn table..belt will then be visable..Advise: belt may not need replacing.. check that it has`nt just come off the drive motor..!
Feb 26, 2010 | Audio Technica AT-PL50 Turntable
Belt came off when I moved it, just need to know how to put it back on. I know that it should be on the golden spinning part, how else is it placed?
Hi put the belt on the platter first, remove the rubber cover and then place the platter back on. There should be a hole through the platter where you can grab it, then stretch it to go over the motor spindle. Hope that helps
Jul 10, 2009 | Audio Technica AT-PL50 Turntable
My audio-technica PL50 plays 45s at the wrong speed.
believe it or not not it probably doesn`t even play your lp`s at the right speed? Its probably because your drive belt has actually stretched? rubber belts do wear and maybe seek out a replacement drive belt?
try this company?
mailto:[email protected]
May 19, 2009 | Audio Technica AT-PL50 Turntable
Belt is off my audio-technica turntable at-pl50
Apr 24, 2009 | Audio Technica AT-PL50 Turntable
Preamp seems to only play bass range
Your query incomplete. Please resubmit.
Dec 16, 2008 | Audio Technica AT-PL50 Turntable
Belt Drive
The belt is replaced as in the following diagram from the manual that you can download on the link below: http://www.lpgear.com/at_pl50_om.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 27, 2007 | Audio Technica AT-PL50 Turntable
32 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
GFXTech
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
