Question about Jet Health & Beauty
I bought a used Jet 3 ultra and I didn't get the owners manual. Where can I buy one?
Posted by Rebecca Thompson on
Terry
  • Jet Master
  • 11,377 Answers
5 Related Answers
william bennett
  • 945 Answers
SOURCE: Need to know where to get a manual for Jet 3 Ultra
http://www.pridemobility.com/jazzy/jet3.asp
this should be of help.
Posted on Oct 15, 2009
lennieg2000
  • 692 Answers
SOURCE: Wife's Jet 3 Ultra ; The Owners Manual Mentions a
liv If you look under the front of the chair below the footrest and can see the lower front of the battery tray there is a 50amp circuit breaker on the front right side of the tray. The circuit breaker is mounted in the tray and I don't know if you have access to it without removing the seat and lower shroud. I have seen very few problems with this tripping unless there are battery issues or old motors drawing too much current. Just don't put the chair in a bind like up against an object and trying to make it go forward in full speed. You shouldn't have problems with a new chair with this tripping. Hope this helps you
Posted on Nov 19, 2010
wcdoc1953
wcdoc1953
  • 280 Answers
SOURCE: I HAVE A JET 3 ULTRA CHAIR, WE LOSS THE 24V PRIDE
You can use the AC charger cord from a computer as a replacement for the AC cord of the charger. If the AC cord plugs into the wall and plugs into the charger or charger receptacle on the back of the power chair, you can use it.
If I remember correctly, This chair has a 4 Amp on-board charger which has an AC receptacle on the back of the chair to plug in an AC cord. The off-board chargers take a universal AC cord which will work with a universal computer AC cord. If the AC cord plugs in, use it.
Posted on Nov 25, 2010
lennieg2000
  • 692 Answers
SOURCE: How do I know if my jet 3 ultra is charging? I
The chair should have a meter on the rear panel where the 9 pin connector for the joystick plugs into the chair when you plug in the charger cord the meter should move up and the lights on the joystick should flash indicating the charger is plugged in. When the chair is fully charged the meter should read zero or bounce up and down. Hope this helps
Posted on Feb 03, 2011
lennieg2000
  • 692 Answers
SOURCE: I BOUGHT A USED JAZZY
Locate the two wires from the circuit breaker attach one wire (black if marked) to the negative post of the rear battery and attach the other wire (red if marked) to the positive post of the front battery. Locate the two wires coming from the power module plug with a red and black wire. Attach the red wire to the rear battery positive post and the black wire to the front battery negative post. attach the joystick to the nine pin plug at the rear of the chair and turn it on. You should have power at the joystick and the chair should work. Disconnect the joystick put the shroud cover back on grease the seat post and reattach the seat then plug in the joystick and charger plug at the rear of the chair. Charge the batteries before use and charge them overnite for the next 20 days. If you use the chair daily charge your batteries everynite while you sleep unplug in the morning. If you don't use the chair daily charge at least once per week or after you use the chair. Always put the chair up fully charged if you are going to be out of the chair for an extended time the disconnect the batteries at the large plug going to the power module Hope this helps you
Posted on Apr 13, 2011
My sonic 3 wheel scooter will not go status light blinks 3 times the 1 time,3 times then 1 time ect, batteries fully charged unit is in gear what is wrong
Pride Mobility Products Corp. - Product Owners Manuals ...
www.pridemobility.com > Resource Center
Pride MobilityProduct Owners Manuals & Specification Sheets ... Jazzy Elite ES PortableSpecifications ... I 02/03. Jet 3 Ultra ... Travel Scooter Throttle Control Lever OperationProduct Insert .... Brochures · Owners Manuals · Basic Operating Instructions · BasicTroubleshooting Instructions · EMI / RFI Information · Warranty Information.
Sep 25, 2015 | Pride Sonic 3 Wheel Portable Scooter
Pride Jet 3 Ultra 4500 rpm, unit is completely dead, am I missing an auxiliary charger or is it built into the unit?
I suggest that you start with determining the condition of your batteries and work outwards from there. Dead batteries just don't want to take a charge. Test your batteries with a meter before you start part swapping. The internal charger is only about 4 amps so it will take many hours to charge a 24volt system.
May 06, 2013 | Jet 3 Ultra Power Chair
Hi i have a Jet 3 Ultra and I need a new Joystick. Where could I buy one? How much would it cost? and can you buy this on its own or do you have to buy the whole hand piece?
Good day,visit the manufacturer website & go from there.Alternatively,ebay is a trusted site to purchase parts also.Have a nice day,Colin.
Jul 26, 2011 | Jet 3 Ultra Power Chair
How do I know if my jet 3 ultra is charging? I just bought a used one today and do not have a manual
Feb 02, 2011 | Jet 3 Ultra Power Chair
I have a jet 3 ultra and send to my country is chile, Chile's electricity is 220 volts, then went to buy a power transformer as used here in is 110 volt. at the store told me that if you have transformer...
Jet 3 is typically 50 amp.
The controller is 40 amp.
What do you mean transformer?
Are you trying to charge? Do you have an onboard charger or separate unit?
I owned a medical equipment company for 10 years, so I know a bit about these, please provide more specifics as to what you are needing.
Jan 24, 2011 | Jet 3 Ultra Power Chair
Where can I get the manual for Jet 3 motorized power wheelchair
acampbel I went to pride website and could only find the manual for the Jet 3 ultra. I don't know if that manual can help you but goto pridemobility.com and select Jazzy chairs, scroll down until you see the picture for the Jet 3 Ultra click on the picture and you can download the manual from that page. Hope this helps you
Sep 15, 2010 | Pride Mobility Products New Pride Mobility...
On my Ultra Jet 3 th power lights keep flashing?
Count the number of flashes IE 3 flashes a pause then 3 flashes this is a error code and tells the tech what the problem is. Without knowing the number of flashes I cannot help. If you have your owners manual there should be a page for error codes somewhere near the joystick page
Aug 16, 2010 | Jet 3 Ultra Power Chair
JET 3 POWER CHAIR SEAT REMOVAL
Sometimes it just takes some real elbow grease to remove those. Try two people one on each side.
Mar 30, 2009 | Jet 3 Ultra Power Chair
Health & Beauty Logo
Top Jet Health & Beauty Experts
Marvin
Marvin
Vincent G
Vincent G
ray gallant
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
